EMachines HAVE LABEL TELL ING MODEL.
NOBODY CAN GUESS IT.
AND THE MANUAL IS ONLY GOOD FOR 1 MODEL.
AND MATTERS HUGE, GETTING SAID MANUAL AND
FOR DESKTOP IT SHOWS HOW TO RESET ALL THAT.
LAPTOPS , NOT EASY IF AT ALL.
Larry picks up a question from 2015 ;>)
Larry Ng Feb 07, 2022
no PC model told hopeless
If desktop, the jumper on the MOBO marked PW_CLR
on most. Never laptops
SOURCE: BIOS RESET
There is hack software out there for cracking the BIOS password and resetting, don't take me wrong, I don't get into hacking but where I work at a Uni its a useful tool if used legally
SOURCE: I set the power on password on my ibm 600e and now cant turn it off. How do I do that
set a power on password in bios but now I want to tuen it off. I get into bios but the ower on icon stays locked. how do I remove the password? Thanks
SOURCE: Bios password on acer extensa 4620
ok on all desktops there is a jumper on the motherboard conecting 2 out of three pins and on the motherboard it says psswd. power off and unplug it then remove the door on the back where the ram goes ill bet thats where ull find it. take the jumper off and put it on the other pins. boot it up and password should be dissabled go int bios and make sure. u can leave it like this or turn off and replace the jumper. hope this helps.
P.S. if the jumper isnot by the ram check behind any other doors the laptop might have
SOURCE: how to remove password from hp compaq dc5700
This may help you. Follow the link
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64180&taskId=135&prodTypeId=12454&prodSeriesId=3249646#10
Read Troubleshooting guide Under Troubleshooting Information. And Computer Setup Utility Guide Under User Guide. I think its more complete on steps by steps guide if you are missing some important steps.
Goodluck
SOURCE: How do I remove forgotten BIOS password?
1) You can reset BIOS to default settings by pressing <Alt><F>
2) I am not sure about the laptops, but in the Dell Desktops usually there is a reset jumper on the motherboard which is seated on 2pins out of 3, you just need to remove that jumper turn on the pc once and the turn on the pc again by reseating the jumper to its original place. You can try this with your laptop, I guess the jumper should be somewhere close to the CMOS battery.
3) Remove the battery and keep it away for atleast 30 mins. and replace it again.
NOTE: make sure while following step (3) and (4) the system should be completely turned off. Unplug the AC adapter, remove the battery and hold the power button for atleast 8 - 10 seconds.
let me know the output
When you boot up to the log in screen type in administrator as user to log in if you cant log in
Restart your computer during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
if this fails to remove your password
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password
also
if you are not the computer administrator and have not assigned a bios password during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also click start control panel user accounts on the users tab,click the name of the computer administrator you must have full control can change the password there
what computer and which operating system?
hope this helps you
When
during
there
also
The
battery power, the BIOS/CMOS settings will be erased. Hope this helps
When
during
there hope this helps
also:
The
battery power, the BIOS/CMOS settings will be erased:. Hope this helps
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there hope this helps
also
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off the battery power, the BIOS/CMOS settings will be erased. Hope this helps
When you boot up to the log in screen type in administrator as user if you cant log in
During the boot up process you will see on the screen for a short amount of time a certain key to enter set up press and hold that key to enter set up BIOS scroll to set user password or supervisor password you can change or remove the password from there if you are still unable to change your password you might download
http://download.cnet.com/%7Bvalue=http://www.download.com/ubcd4win/3000-2086_4-10550208.html
UBCD4Win is a bootable "live" CD which contains software that allows you to change paswords repair/restore/diagnostic almost any computer problem also has a bios reset tool which remove your password and BIOS password although you will have to use a computer with an internet connection you will have to burn it to a disk as an iso then change your firtst boot device to cd During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed the password you must go back and change the first boot device to your hard drive)
Hope this helps
Hope this helps
IF YOU HAVE NOT PUT A BIOS PASSWORD
Hope this helps
when you boot up to the log in screen type in administrator to log in if you cant log in
During the boot up process you will see on the screen for a short amount of time press a certain key to enter set up
or
on the users tab,click the name of the computer administrator you can change the password there
hope this helps
Hi Alvin Tray, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?''
no model told and not told is desktop or laptop.?
if desktop
there is a jumper on the MOBO marked
PW_CLR
on most. never laptops
nobody can guess 1000 of PC models. why asK?
am now necro-king of this galaxy.
most answers are the same for all PC.s
about 20 things wrong, and up to 20 tests to find them so I answer them all. try.
like screen dead
or lost PW asked here 10,000 times.
and no pC told.
