SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Hi, There are three ways of repairing, 1- Contact nearest Sony Service Center and they will estimate you to replace the Complete Optical Unit, which would be costly but reliable,
2- In second way, Contact any repair man nearby and he will open the Optical Unit Assy. and and try to fix it (most probably it is only misaligned).
3- Third method is free of cost and chances are 50/50, the face of optical unit (Lens) keep down and keep press it normally and in the meanwhile turn its power on. The Lens of the camera will try to open keep it press slightly not with full power :) . After few tries turn it off. After that in normal way turn it on and hopefully it will work fine again. If No.3 method successful keep remember me :) Thanks
It may be your missing a CODEC in your PC. However you have several options. Try downloading and installing 'VLC media player', that plays most video clip types including AVCHD.
A couple of good video format converters are 'Handbrake' and 'AnyVideo Converter'. Both are free downloads.
I'm sorry to inform you that the DSC-WX9 dos not work as a web cam. It only connects as [MTP] or [Mass Storage]. It doesn't have PTP that allows cameras to work as web cams.
You should be able to plug in the USB cord that came with the camera. Connect the one end to the camera then the other end to a USB wall charger or your computer. If you no longer have the USB cable, you can purchase one here from Amazon.
