Question about Roper Washing Machines
ROPER WASHING MACHINE KEEPS REPEATING THE FULL CYCLE WHY????
My Roper Machine keeps repeating the full cycle to wash and wont stop, the wash cycle will complete but keeps starting over, and the lid is locked so I cant stop it and get my things out, I have unplugged it but still cant get it open, sometimes Im lucky enough to stop it myself and get my clothes out. Please tell me what I need to do and what could be wrong with it. Thanks in advance for your help please help. Thanks
Posted by Lynn Graham on
Claude Kayser
    Top Expert:
  • Roper Master
  • 9,098 Answers
The timer is at fault, or a cycle sensor.
Posted on Jul 15, 2015
Greetings, and thank you in advance! I have a Roper Heavy Duty Super Capacity 7 Cycle Top Loading Washing Machine.
sounds like you need to call a repair service . motor or transmission may have went out
Mar 16, 2017 | Roper Washing Machines
My Roper washing machine keeps filling and draining in the final rinse cycle.The lid lock light flashes and the machine will not complete the wash cycle, just keeps filling, spinning and draining!
Depending on your model, it will either have an electronic or mechanical timer. If electronic which it sounds like, you likely have a bad board or control unit. If mechanical you will need a new timer.
My old washer was mechanical and I had to replace the timer several times over 18 years. My new Samsung is all digital so when it goes bad, will have to diagnose the circuit that needs replacing. Normally there is an error code on the LCD readout.
Mar 20, 2016 | Roper Washing Machines
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Nov 26, 2015 | Washing Machines
Aquasmart lid
Is the lid lock tang on lid broken.
2.9 Lid Lock
The Phase 7 Washer uses the same lid lock that is used on
the Phase 6 series 11 & 12 machines. The difference being is that the lid is now locked for the entire cycle. When the lid is locked the Lid Locked LED will illuminate. Once the spin
has completed, the lock will release and the lid can be
opened. To open the lid during the cycle the
START/PAUSE button must be pressed, the machine will
come to a halt, and the lid locked LED will extinguish.
If the lid is left open, the machine will be unable to lock the lid
and the cycle will be halted. The machine will play a tune
and the lid lock will flash until the lid is closed and START/PAUSE is pressed.
• If the lid-lock fails in the closed position, the locked lid can be forced upwards and out of the
lock. Note: This is the only time in which we would recommend doing this.
• If the harness is damaged, the complete lid lock assembly will need to be replaced.
If the power supply is cut during the spin cycle, the machine will keep the lid locked until the rotor has ceased to turn (3 to 10 secs). Only then will it release the lock. The motor is acting like a generator and allows the lock to stay energized under the bowls inertia.
Mar 16, 2013 | Fisher Paykel EcoSmart GWL15
Roper rax4232pqo wont spin
Still replace the lid switch. Most have multiple contacts.
Nov 08, 2008 | Roper RAS8445KQ Top Load Washer
Washer won't run through a complete cycle-stops at 29 minutes
There is a service manual behind the control panel it will show you how to test the door locks. If might have a bad lock solenoid.
Aug 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Roper 7 cycle
sounds like a bad lid switch, agitates but doenst advance to rinse, remains full of water?? if so lift the lid up and downa few times hear a "clicking" noise??machine doesnt think lid is closed so for safety reasnos wont spin/drain replace the door latch part number3949247
Mar 04, 2008 | Washing Machines
Washing machine does not stop filling
Does the machine start working normally after turning the wash cycle manually ?
Feb 15, 2007 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
308 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Gerry Harvey
Gerry Harvey
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
