Question about Video Game Consoles & Games
How do I fix 0xc00007b on Spider-man Shattered Dimensions on the computer?
When I open the game it shows me this message "The application was unable to start correctly(0xc00007b). Click OK to close the application." I downloaded all its requirements
Posted by Alpha Kills on
Bruno Duarte
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 30 Answers
Error 0xc000007b
fix 0xc00007b error "the application was unable to start correctly"
there may be multiple reasons as to why you might receive 0xc00007b error when trying to run an application on a windows machine. 0xc000007b error usually comes from mixing up 32bit environment with 64bit one. For example 32bit application loads a 64bit dll causing 0xc000007b error.
Solution 1
In most cases it's .NET framework causing issues. This can easily fixed by re-installing latest .NET framework from [link]
Solution 2
Re-install the application that you are trying to run. It sounds simple but the application data files could be corrupt or missing. This could be caused by a installation that did not complete successfully or by a virus.
Solution 3
Running the application as an administrator could fix this error. Right click on the program shortcut or program .exe file, then click on Properties, and on the Compatibility tab. Check the Run this program as an administrator box, and click on OK
Solution 4
Restart your computer as some applications require restart after installation to function properly.
Solution 5
Run Windows update as it can provide application fixes and updates. Furthermore it installs missing drivers and updates the outdated ones like graphic card drivers. Windows 7 / 8 / 8.1 users need to search for "windows update". select all important and optional updates and click on the "install updates" button. If you use Windows XP navigate navigate to Windows Update by choosing Start > All Programs > Windows Update. When the scan is complete,Click the Review and Install Updates link. Finally press the "install now" button.
Windows 7 / 8 / 8.1
Windows XP
Solution 6
manually update the application if possible.
Solution 7
re-install Microsoft Visual C++ from [x32 link] or [x64 link]
Solution 8
re-install DirectX [link]
Solution 9
Many times hard disk problems can be repaired using the chkdsk command. If you are using windows 7 press the start button in bottom left corner of your screen. If you are using windows 8 / 8.1 press the windows key .Search for "cmd" and Right click it and select "Run as administrator". Windows XP users Click on start > run. In the Run box, type in "cmd" in the box.
Windows 7:
Windows 8 / 8.1
Windows XP
A CMD window should appear. In that window you can just type it as you see "chkdsk c: /f /r". If you have more then one drive or partition, you will need to tell it the disk (chkdsk d: /f /r).
If it is the primary windows disk c: it will ask you to schedule it for next boot. When you restart, it will do a chkdsk for you before even getting to the login screen.
Solution 10
This solution only works for a 64-bit system. It requires replacing files is system32 directory so be careful. Only attempt this solution if you are confident and if other solutions have failed. When Microsoft Visual C++ Redistributable Package is not properly configured it may cause 0xc00007b error. Firstly download the zip file [link] and decompress it. Reboot in safe mode and go to C:\Windows\System32. copy all files included in the zip package (mfc100.dll, mfc100u.dll, msvcr100.dll, msvcp100.dll and msvcr100_clr0400.dll) to C:\Windows\System32 replacing the current ones. After that reboot in normal mode.
If all the solutions above haven't worked i would consider backing up data and performing a clean install of windows.
Jan 11, 2016 | Dell Inspiron Computers & Internet
How to fix 0xc000007b problem
This Microsoft Office error code occurs when you are updating installing and copying etc. This error occurs due to router and modem configuration and ISP restriction.
This error can be solved in 4 ways
1. By cleaning temp folder
2. By cleaning the %temp% folder
3. By cleaning the system file
4. By cleaning the Internet Explorer junk
Guide to solve your issue
Open the Run by pressing the window + R keys
Then open the temporary file system location by searching the temp in command prompt
If you have files means then select all the files and clear them by pressing Shift + Delete
This is also similar to clear the temp folder. By this method, we clear the user junk files.
Instead of temp search as %temp% in command prompt and follow the above steps.
Open the Run command prompt
Enter the cleanmgr command
Then select the drive which one want to clean
Then scan for junk data after that choose the entire item from the list except the recycle bin to clean.
Open the run window and enter the inetcpl.cpl command
Then go to advanced tab and select the reset button to clean the junk data
Then you will get pop up to delete the personal settings click ok to delete.
By following the above steps you can resolve your windows error code issues. For further more guidance regarding windows, you may visit the Microsoft Support Number.
Aug 30, 2015 | Computers & Internet
All in one center not working
Please visit the Lexmark website to download and install the Lexmark X4270 Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
Feb 20, 2012 | Lexmark X4270 All-in-One Multifunction...
My nokia n95 cannot send text it says unable to send memory full,close applications and try again
Try to change the message storage memory from phone to memory card, 'cause N95 ship with altest 1GB memory card.. it can be done this way
open messaging > options > settings > memory in use > [select card]
Jan 22, 2009 | Nokia N95 Cellular Phone
I have XP and Norton 360. My ISP, Comcast, said I should disable the program so they can work on a problem. I am unable to open any jpg files. Can you help?
regarding disabling norton i can walk you
just click on start
then click on run
you will get a run box
typein MSCONFIG and press ok
you will get system configuration utility
click on services tab
at bottom there is an option which has a box and a message hide all microsoft applications
now whatever you see has symantic or norton written next to it uncheck that
click on aply then close
you will get a popup to restart your computer just click on restart
once your computer restart
the very first message on the desktop will be a pop up box and you will find a box next to which you will se do not show me this message in future
now norton is disabled you can get in contact with your ISP so that they may provide you troubleshooting which they were unable to due because of norton.
Jun 09, 2008 | Computers & Internet
Video Game Consoles & Games Logo
842 people viewed this question
Top Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
