I did what the instructions told me to do. when i started the washing machine it immediately stopped after 2 seconds but the time still keeps going i think there is something wrong with the draining/unlocking. my washing machine is LAB0050PQ
Before you call for Service, here is the instructions Manual. Troubleshooting starts on page 17
Good Luck!
JP
Whirlpool LAB0050PQ Use And Care Manual
SOURCE: Bosch WFX Excel
You have to replace the water inlet valve, the valve where water enters your machine.
SOURCE: frigidaire washing machine
OK Check elec plug at motor . Mine was doing exac same thing . Take belt access panel off back and pull wire plug off motor and push back firmly on . This plug does not have a tab so vibrates off . Good luck .
SOURCE: Maytag Neptune stops during rinse cycles
Could yoy please explain what the "screen" is?
Thanks,
Carl.
SOURCE: LG WT-R801 keeps draining
If the cycle does not stop draining that is usually because of a faulty
membrane switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
