Question about DeLonghi Dehumidifiers
- When unit get's switched on, fan comes on and dehumidifier cycle light goes on, but no compressor. - after about 3 minutes, dehumidifier light goes off but compressor switches ON. - Only the capilary tube between condenser and evaporator frosts up. When the compressor cycles off, the capilary tube frost melts, giving a few drops of condensation but not enough to reach/fill the tank. - System apprears mechanically sound with some rust on evaporator coil end loops. -I'm better mechanically than with electronics but seems to be a board issue - any debugging thoughts to help isolate the problem?
SOURCE: dead dehumidifier
Pull the bucket out... reach up under the bottom edge of the display bezel and pull down on the back edge to get the filter out; rinse out/off thoroughly, dry and reinstall it...
Get some airflow thru there!
Good Luck!
Posted on Dec 04, 2007
SOURCE: LG LD65EL Dehumidifier doesn't work properly
What do you have the humidity level set at on your dehumidifier? The average is 65%. Make sure you do not have it set at 75% because if you do this could be causing it to keep the humidity so high.
Posted on Jul 08, 2008
SOURCE: Edison 25 dehumidifier coils frosting
Same problem with mine.I've tried to clean mine as well. HELP, I live in a very woodsy area and constantly fight humidy.
[email protected]
Posted on Jul 13, 2008
SOURCE: Water condenses on top of dehumidifier
Your unit has a sealed system leak. The sealed system is warrantied for five years. Check your owners manual for this info. You will need your receipt and to call an authorized LG warranty dealer to exchange it.
Posted on Jan 23, 2010
SOURCE: I have a Goldstar Dehumidifier DH504ELY7 that
There
are many reasons why a dehumidifier will not work or collect water.
Here
is a tip that I wrote to help people to figure out what is going
wrong with their dehumidifier
Dehumidifier
is running but no water is in bucket
heatman101
Posted on Jan 27, 2011
Sep 18, 2011 | DeLonghi DE40P Dehumidifier
Jul 11, 2011 | DeLonghi DE40P Dehumidifier
Jun 27, 2011 | DeLonghi DE500P Dehumidifier
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Feb 09, 2011 | DeLonghi DE40P Dehumidifier
Aug 23, 2010 | DeLonghi DE40P Dehumidifier
Jan 07, 2010 | DeLonghi DE40P Dehumidifier
Jun 25, 2009 | DeLonghi DE40P Dehumidifier
Jun 20, 2009 | DeLonghi DE40P Dehumidifier
May 29, 2009 | DeLonghi DE40P Dehumidifier
Aug 19, 2008 | DeLonghi DE40P Dehumidifier
May 17, 2016 | DeLonghi Dehumidifiers
89 people viewed this question
