SOURCE: Frigidaire freezer 5 cu. / ft.
how old is it ? and if is just humming is etheir a locked compressor wich if it is then depending on age if is less than 5 years from todays date then just call frigedaire and they will fix it for free but is it was manufacture more than five years ago then is trash , now is just the overload then just buy the part and replace it and you will see if it turns on the overload is the part siiting right on the left side on compressor , fyi the maunufactures date is on the name plate on the wall i belived is on the left hand side
SOURCE: Cu feet of Frigidaire Freezer modelffu14fc4cw1
according to your model number it is a 14 cu ft. thx peyton
SOURCE: small upright freezer (4 cu ft) is leaking water
Could be just the coils are iced up, I would pull everything out of it, unplug for a day, plug back in and let it run....
SOURCE: After being unplugged for one year, my Frigidaire
It's probable that you've lost refrigerant in the cooling system. Unfortunately, leaks in those systems can be hard to find so check your warranty to see if the labor is still covered.
stopped up drain,tear in gasket,not going into defrost soon enough
Thank you for your post, friend!
I see you would like to know the cubic footage of your Frigidaire freezer. Based off the model number you have provided it appears that you have a 21 cubic foot freezer. Hopefully this information is helpful. -Matt
