A cracked plasma screen cannot be set right by anyway. It has to be replaced. http://electronicshelponline.blogspot.com/
You have to replace the screen. However, I recommend buying a new TV because a new screen will be expensive and you rather use that fund to buy a brand new TV.
SOURCE: No picture and only buzzing sound coming from plasma with cracked screen
Most of the times this type of damage is due to panel overheating. This can occur due to many situations but most offten is due to internal mulfunction of some of the high power/voltage driving circuits. You can only hope that the dealer will replace the set under warranty. Do not settle with a repair.
SOURCE: Broken Plasma TV
I'm looking for a broken screen HP-S5053 to buy from someone. I have a new screen that needs a home. I need one that is complete and working other than the screen. Or I would sell my screen to you. Thanks, Wade [email protected]
SOURCE: SAMSUNG sp-p4231 sound, but no picture
try changing the display IC that would be the frequent cause of such problems
SOURCE: Samsung Plasma TV have sound but no picture
G'Day!
Unfortunately, what you're describing is a repair
issue. You won't be able to address the problem with troubleshooting.
There is a part inside the TV that needs to be replaced. If you're
under warranty, this will cost you nothing. If you're not under
warranty the cost will likely be a minimum of $200 parts and labor.
However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from
here. Please be sure to vote on my response. I hope I've earned a
good rating from you today.
Please post a comment if you need
additional assistance so that I can help you further
SOURCE: samsung plasma 42 inchs with sound no picture
Most likely your Y Sustain panel has gone bad. I would have a qualified service center evaluate it to be sure.
