Cuisinart Cbk-200 2-pound Convection Automatic Bread Maker Logo
c
christy Posted on Jul 13, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I prevent crust from burning?
No matter what setting I set on this bread baker for the crust it ends up burning.
Surjel Castaeda
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Jul 13, 2015
Surjel Castaeda
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
2066
Points
24
Hope this can help: http://www.overstock.com/Home-Garden/Cuisinart-CBK-200-2-pound-Automatic-Convection-Bread-Maker/5190276/product.html
Christine Cowley
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 04, 2021
Christine Cowley
Contributor
Level 1:
Answers
Questions
0
Helped
1291
Points
Kami
Level 2:
An expert that gotĀ 10 achievements.
Novelist:
  • Expert 307 Answers
  • Posted on Nov 04, 2018
Kami
Expert
Level 2:
Novelist:
Answers
307
Questions
0
Helped
155757
Points
375
Other than a machine malfunction, too much sugar, honey, milk, or egg in the dough will cause yeast breads to burn.
Bread crust burns even on "Light" setting
Contact Oster for advice. Here is their contact info-
https://www.oster.com/contactus?cid=contact-us
My crust isnt dark enough
Change the crust selector to "Dark" on your next loaf
The bread burns and won't come out
try a lighter crust setting. Are you using any type fo fat (light oil or butter)? You should. Also spray the pan and paddles with Pam or other non-stick spray before placing your ingredients in the bread pan.
5helpful
Need the operting Manual for PerfectBaker PB571
Here's some info;
http://www.creativehomemaking.com/download/TR888_1183_Recipe_Book.pdf
Here is some operating instructions one baker used for this machine;
But here's how to actually use it:
Put wet ingredients in loaf pan. Heap dry ingredients on top. Make a well in dry ingredients and add yeast, ensuring it doesn't touch liquid if you want to use the timer. Put pan in breadmaker, clicking into place.
Plug in breadmaker but DO NOT touch the on/off button till the very last.
Using the "menu" button, choose what type of bread you're making (the top two rows -- normal, fruity etc).
Using the "crust control" select how dark you want your crust.
Using the "timer" select how long till you get the finished product. The minimum is 3 hours for quick bread/medium crust, which I often use, the maximum 14 hrs 30mins. It goes up in 30 minute increments with each push of the up arrow. Remember, what the timer shows is when the finished bread will be ready.
Once you're satisfied with your settings, press on/off
If you choose "fruity bread" the timer will beep into the kneading process to tell you it's time to add the fruit. It goes in at a later stage.
When the bread is finished, it will keep on a warm cycle for a while until you switch it off.
I use high grade flour and add 1 tsp gluten flour to each cup of flour. The bread rises more.
Crust is always dark and hard no matter which setting I use
Just pull the plug on it when it has about 15 minutes left
1helpful
2answers
Burns bread before it can get done. Tried it three times. I am making a 1 1/2 pound loaf of sweet bread. I tried setting it to one pound and light crust but it still burns the bread before it gets done. I...
Look very carefully where the bread pan goes in. There is a heating element around it. If the bread pan is too close or touching the heating element ( the round thing running around the wall), it will burn the bread. You can try moving the bread pan away from the heating element. If you try and bend the heating element, it may break the element, so move the bread pan only.
1helpful
The bread is too dry
Welcome to FixYa, if you appreciate our solution, please rate our services.
Breadmakers usually don't have as many crust settings as this one does. Darker crust settings usually equate to dryer bread because the bread bakes longer. The longer the bread bakes, the more moisture is removed. Accordingly, if you've tried this many recipes with dry texture, try progressively lighter crust settings until you get the moisture you desire. As for me, I rarely bake my bread in the machine (I don't like the hole in the bottom of the loaf). I do, however, appreciate the dough setting which does all the hard work, and I just bake it in the pan. I think the results are better and I get a better shaped loaf.
If this information has been helpful, don't forget to give me an appropriate rating. Thanks again and good baking!
1helpful
My crust keeps burning
It seems like the strength of the heat/oven varies a lot from a machine to another... Mine works great with most recipes, but my parents' burns the crust everytime. The only adivce I can give you is to check on the baking process and stop your machine when the bread has a golden crust. It doesn't solve the problem, but at least you get your bread...
Top Cuisinart Kitchen Appliances - Others Experts
Mike Cairns
Mike Cairns
Stan Ford
Don A
Don A
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
