I am trying to replace the spark electrode. The gasket/seal around the burner is broken. They are 3 and 4 inches in diameters. I can't find anyone who carries them online with pictures. Are they standard parts for all stovetops?
www.repairclinic.com/Shop-For.../Gaggenau-Range-Stove-Oven-Parts Huge selection of Gaggenau Range/Stove/Oven parts in stock. Same day shipping. Open 7 days a week. ... Door hinge, top/bottom. OEM Part - Manufacturer # ...
The spark module is in the ignition circuit for the gas burners. When a burner control knob is turned to the Lite position, it provides voltage to the spark electrodes on the gas burners. If the spark module fails to provide the electrodes with voltage, then it should be replaced.
First you need to brush out the end tip of the sparking electrode and the burner metal part facing the electrode so they can create a spark. If not any result the you should remove electrode and check if the ceramic cover is broken and the sparking goes in wrong way and you will need to replace it.
The electrode (spark plug) for that burner is not telling the spark module the burner is lit and go ahead and turn off the spark. That electrode and the wiring on it need to be replaced,from that burner back to the spark module. I found this place online that sells that part http://www.expertappliance.com/partfinder-gas-stove-elite.php
Hi, This could be caused by something spilled on the burner, look at the electrode where the spark comes from and clean it up and make sure the metal right above it is clean as well. You should see spark at each burner regardless of which one your turning on. Assuming everything is clean, if you don't see spark on 2 of the burners, it could be 2 broken wires or a defective spark module (not likely if right side lights). Good luck
Make sure the area of the burner base around the spark electrode is clean (use a fine sand paper). The little hole for the gas is open (use a paper clip). You won’t see a flame unless the burner head is on. If this doesn’t help, check the bottom of the spark electrode visually. Make sure the wire is attached to the electrode and is not loose (pull it a little bit.) If the wire or the electrode is damaged, replace it ($25). If not, locate the spark module and switch the connection with another one (they are different colors). If you get flame on the same burner, but not on the other one, replace the spark module ($60). When you work with electrical components, turn the breaker off. When you test, turn it on. Good luck.
is this a sealed burner unit? if so the burner base (the heavy brass part under the burner cap) has to be sitting just right. you will notice that it has holes around the the sides make sure that where your ignitor sparks to it that it aligns with the lowest hole on the burner base. if you have a great flame all around the burner after checking what i mentioned i would replace the spark module. if it continues to drive you crazy with the noise - just unplug it. the burners will continue working fine without power.
first thing is the spark module(ignitor-- your referring to) is probably good and your electrodes are damaged. more then likely the problem. when you turn on one burner they should all spark( 1 module controls all 5 electrodes) so lets check that, first. when you turn on any/all burners do you at least hear clicking??. theres a switch under each **** that turns on the spark(erhaps one of them is bad. think of the electrodes as spark plugs on a car, they spark the same way, ck to see that they are clean(free from rust and carbon build up).using emory cloth or a woman's finger nail file try "sanding" down to a shiny surface the very tip of the electrode protruding out of the burner head.look for cracks in the porcelin housing around the electrodes this will lead to miss fires of the electrodes
