Hi Kathy, It sounds like you have a very sad and lonely little oven! I think that you might have to get the nice doctor man out to it! Seriously, unless it's throwing up an error code, I can't think of any other solution. Just make sure that you get an idea of call out charges before engaging anyone.
SOURCE: Oven comes on for no reason followed by the start beep
yes you can kill the power and lock out the box with a pad lock for safety. the panel is attached by screws usually on the bottom of panel. lower and seperate the control panel ribbon from the erc (electronic range control). without removing any other components leave ribbon loose and replace panel. turn power back on. if the beeping does not recur, the control panel probably has a stuck key. if it does resume the erc is faulty
SOURCE: I have a Kenmore Model # 911 4842 992, Serial #
sounds dangerous...I would change the control panel
SOURCE: Whirlpool RBD305PD has error F2E6 error on control panel
When this code appears and display is going blank too, it is always the control board. The only option is to buy a new one or get it repaired. It can be fixed quickly and reliably. www.fixyourboard.com
SOURCE: Whirlpool Gold double oven -
I was just looking over a manual for a late model double oven. Their is a thermal limit going into the controls that will open if the temp rises enough to harm the controls. They look like this one. That kills all power to the control and you will see nothing on the display.
This manual will give an idea where to look:
Late model double oven
Helpful?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
