SOURCE: Vulcan 300 Freeloader Gas Water Heater
I assume it has a pilot. Try blowing out the pilot area with compressed air or CO2. Then relight the pilot.
Dust can cover the pilot combustion air inlet and cause it to pull away from the safety generator or thermocouple. Its called an oxygen depletion arrangement on some space heaters. I assume your Domestic Water Heater has this setup as well. Even if not the thermocouple is not getting all then heat from the flame. If this doesn't work get back to me here. We'll try 1 more thing.
If this helps you please grade me accordingly. GOOD LUCK
SOURCE: Hi my vulcan gas wall heater goes 'bang' after a
it sounds like delayed ignition, this is VERY dangerous, you need to verify sequence of operation and fuel air mixture.
SOURCE: Pyrox natural gas heater not functioning properly
Clean the burners out with air pressure,like from a air tank,and a blow gun,then clean the pilot light orifice(this is where the pilot light is)if this does not help,replace the thermocouple ,it will be the problem,if this was at all helpful,please rate,thank you.
Testimonial: "Thanks for your help. Have located the problem now thanks. It's the gas line. Strong smell of gas outside. Grateful for assistance. "
SOURCE: i have a problem with a pyrox gas heater that
check too see if pilot is clean and check air ports to pilot could be blocked
SOURCE: pyrox /vulcan model no 4720006
Hi Chastrix,
Are you follow the below steps to start up your device?
Hope this helps..:)
Let me know in case you have any queries.
