Question about Toys
Looking for replacement engine,or short block
For massey ferguson tractor
Posted by David Rudolph on
Mister Danger
  • Toys Master
  • 5,631 Answers
How do you wire Massey Ferguson 230 diesal ? With 3 wire delco alternator. Along with oil pressure switch , ammeter, neutral safty switch, fuel,water. 12 volts.
    mages for wire diagram Massey Ferguson 230 diesel
    More images for wire diagram Massey Ferguson 230 diesel
    230 MF - wiring diagram - SSB Tractor
    www.ssbtractor.com/wwwboard/view_all.cgi?bd=massey&msg=10416
    Allen Stewart, I need the wiring diagram of the dash area. Does anybody have this? Allen Stewart, wiring diagram is needed for Massey Ferguson 230 diesel.
    [PDF]MASSEY-FERGUSON - MyeDocs.com
Jan 01, 2016 | Toys
Who has manuals for the Massey Ferguson 230?
contact the manufacturer on line for any available pdf downloads.
try e-bay for manuals.
May 04, 2015 | RTO Massey-Ferguson Tractor TE20, TO20,...
What is the main bearing bolts torque.the connecting bearing bolts torque and cylinder head bolts totque for E3CD engine in 1540 massey ferguson tractor
I don't have your answer but if you google torque specs for your engine I'm sure you will find your answer. When I'm not sure I will call a dealer and they will most likely help out with the info
Dec 05, 2014 | Cover My Tractor Tractor Cab-Enclosure for...
Lookup serial numbers
Hi, here's a link to these specs. It looks like however that you did also find this info. Perhaps you'd comment if this was helpful. Thanks and good luck!
Just in case:
TractorData.com Massey Ferguson 362 tractor information
http://www.tractordata.com/farm-tractors/000/7/8/784-massey-ferguson-362.html
Aug 30, 2014 | Garden
What sort of oil is used in the gearbox of a massey ferguson 28 Te 20
The Massey Ferguson's use the same oil as the N series tractors. 90W for the transmission.
Apr 29, 2010 | RTO Massey-Ferguson Tractor TE20, TO20,...
Need a wiring diagram for a massey ferguson 135 tractor
I need a wiring diagram for my massey ferguson 135 tractor regards ****
Mar 24, 2009 | RTO Massey-Ferguson Tractor TE20, TO20,...
Toys Logo
717 people viewed this question
Top Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
