Question about Dometic RM2652 Refrigerator
Dometic refregerator 2652, the inside refer. light and the check light on the front blink when i open the refrigerator door. then stops a bout 20 sec. after closing the door
Posted by marian west on
Jerry Smith
  • Dometic Master
  • 473 Answers
Sounds like a possible loose connection somewhere that is shaking when the door is opened. Check the main plug/power connection to the refrigerator for corrosion or just looseness. The inside light is controlled by a door switch so you may have a connection problem there also.
Posted on Jul 12, 2015
Have a dmetic rm 2652, have power in fridge but no freezer or cold in fridge,tried restarted 3-4 tims still no good,trieda new 5 amp fuses ran 3 minutes stopped again?
On most Dometics, When you have a cooling problem follow these steps and it will resolve your problem or at least tell you what is wrong.
Check main terminal Block for proper Voltage
Check Heating element for proper ohms, 2652 is 44ohms
Disconnect P-2 wire on board for approximately 12 to 18 hrs. This makes the unit run constantly in case there is a clog in the unit.
The only other thing you may do is check the thermistor operation, Unplug the P-2, remove the thermistor from inside the refrigerator, put it in ice, You want the thermistor to drop to about 32 degrees, Check the ohms, they should be at 8,000 to 10,000 ohms.
If all checks out, you have either a bad board, not common, or a bad cooling unit, common
Jun 11, 2010 | Dometic RM2652 Refrigerator
RM 2652 will not get cold
Check the 5 amp buss fuse behind the frig.
Apr 04, 2010 | Dometic RM2652 Refrigerator
Travel trailer refrigerator will not get cold
Model 2652 Refrigerator The fridge has been perfct till this last trip. the auto light is on and its not getting cold no red lights and i have pluged in as well as unpluged propain is full but i see some yellow dust inside the big cyinder.we may have left the frezzer door open for a couple hour.
Jun 04, 2009 | Dometic RM2652 Refrigerator
Dometic rv refrigerator
I found that they rewired the 12 volt supply, red wire, thru a heat safety switch on the burner unit and it was open instead of being closed and cut off the main 12 volt supply to the control board. I connected a jumper wire around the new switch and the frig works . either the new switch is bad or too close to the heating unit.
Oct 22, 2008 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
189 people viewed this question
Top Dometic Refrigerators Experts
Sheldon Dedek
John Tripp
John Tripp
Paul G
Paul G
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
