Question about Mitsubishi Televison & Video
WS 65809. How do I replace the green lamp?
The green lamp is not working. where can I find a replacement lamp and how to replace it
Posted by Ron De Souza on
johnny rebel
    Top Expert:
  • Mitsubishi Master
  • 10,875 Answers
My Mitsubishi WS-65809 turns on and then off after about a miniute, the lamp light turns red
I think some confusion here, The model indicated is a WS series set does not use a lamp but has three picture tubes and the power light should be green on this model (ie no lamp light).
Want to try this again?
Dec 12, 2012 | JVC HD-61FH96 61" Rear Projection HDTV
I have a Mitsubishi WS-65809 that I am having convergence problems with. The Red and Blue appear fine but the Green is the problem. The Green bows down on the bottom and up on the top. I have replaced the...
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 14, 2011 | Mitsubishi WS-65809 65" Rear Projection...
One of the lamps on ws- 65809 is not working need to know where to get the part and how to remove it
Can't get the part as the tv is 10 yrs old, have a professional technician do it. not for beginners
Jul 31, 2011 | Mitsubishi WS-65809 65" Rear Projection...
My Mitsubishi WS-65809 displays a 2 blink pause 2 blink sequence when the menu and input buttons are pressed and held at the same time. What does that indicate?
tHats indicating a short. Check the two green pico fuses F9A04 and F9A05 on the center board if they are blown replace the two 5 amp picos and the convergence Ics.
Jun 10, 2009 | Mitsubishi WS-65809 65" Rear Projection...
No Red, can't adjust Red convergence, Blue works fine
looks like the red "bulb" has blown.
you need to replace but can be expensive.
Apr 28, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Blurred Picture Mitsubishi WS-65809 65"
the convergence IC's will most likely need to be replaced as well as a resistor or two
electech
Oct 29, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65809 Dim Lamp
Good Day, cantseewhat;
It sounds like your TV has a problem. It could be and most likely be CRT Coolant on the circuit boards. If you handy, then clean PCB's with acetone on areas which fluid appear. If not handy call aN Authorized Sevice Center and have them give you a written estimate B4 repairs. Cost $450.00 to 650.00 depending on your location. Good Luck, big IRISH.
Sep 16, 2008 | Mitsubishi WS-65809 65" Rear Projection...
MITSUBISHI 65"
You need to replace both convergence ICs Number STK392-570 If your model number is a WS-65809 you can get new replacement ICs at the following link and they provide instalation instruction with pics as well as free on line tech support so you can do the repair yourself.
http://servicemanuals.vstore.ca/
Apr 30, 2008 | Mitsubishi WS-65809 65" Rear Projection...
MITSUBISHI 65" WIDESCREEN MODEL WS 65809 (GREEN GONE, SMALL RED LINES)
in the front cover turn up screens on all colors till you see retrace lines, then back them down to where dissappear. enless you know the correct voltage to set it. as for the green. i would try the red crt on the green and see if it looks ok. if so then replace crt circuit or check transistors on crt circuit may also need to change the driver on the heat sync.
Apr 09, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Televison & Video Logo
109 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
