Question about Pets - Others
After replacing all batteries, why does the receiver on the dog collar emit low volume beeps?
No other functions work. No vibration, sounds of shock available
2 Related Answers
Anonymous
SOURCE: My dog's SmartPets 4in1 Dog Training Shock and Vibration Collar has stopped working
It seems like your batteries have run out - you can buy new batteries from here http://www.amazon.com/PetSafe-6-Volt-Lithium-Battery-Batteries/dp/B0009811TW/ref=pd_sim_petsupplies_8 The battery is very easy to change, the handset also runs on batteries but they are AA and can be purchased from your local store.
Posted on May 13, 2012
p_l_ross
Paul Ross
  • 20 Answers
SOURCE: Innotek shock collar
I had same problem with an Innotek Bark collar. However after my dog s barking caused shocks the first times he wore it and quickly he changed that behavior. It finally and quickly got to the point that I still used it on him but I never had batteries in it as just wearing the collar was enough to stop his annoying the neighbors. These collars do not have a long lifespan like most electronic goods.
Posted on Jul 05, 2012
Garmin delta xc doesn't shock
Disgusting thing to use on your dog. Training them by pain, only makes them afraid of you.
Use patience and reward, it works better and
your dog will love and obey you.
How to set the collar of a Petafe in ground fence.
1st you have to hold down the little black button on the collar, when it flashes at you release the button.
-Then press the button again and count the # of flashes.
-Keep pressing the button until you get it set to the desired flashes related to the setting you want to use.
-1 flash- audible correction with no shock.
-2 flashes audible correction with low shock.
-3 flashes audible correction with high shock.
It is always recommended to start with the low shock , if using shock setting, then move to higher setting if needed. Most larger dogs require a high shock setting, I have a yellow lab and use the high setting for him. Hope this helps.
1helpful
Shock Collar Won't Work
Please don't use this device. I used to use these on my poor dogs for training..then I received a shock from the collar myself and it hurt like hell! (I also had undergone a test that used electric current to "test" my muscle reflex..boy, did that hurt..had to make them stop the test and asked "how could you do this to someone..it's like a form of torture!! Dawned on me that that's exactly what I was doing to my poor dogs!!)So, please have a little compassion..there are other ways to train your dog. Like positive reinforcement!
Feb 03, 2013 • Dogs
How do Dog hunting collars work?
If you are referring to remote trainers' collar then please know that all remote trainers have the same basic 3 components: Remote transmitter, Collar receiver and collar probes.
The transmitter sends a radio signal to the collar receiver. Then, the collar delivers the stimulation to the dog through the stainless steel collar probes. The probes are located on the dog's neck and must have direct contact with the dog's skin in order to properly function.
Jan 14, 2013 • Hunting
2helpful
2answers
Esky remote control dog collar
My Esky dog collar does not work in any mode. The first problem was when the collar would not stop beeping. Now it will turn on, but it will not beep, vibrate or shock. What do I do?
May 26, 2012 • Dogs
Do dogs get annoyed by collars with bells on them?
Bell collars are probably uncomfortable on most dogs becauseof the high pitch sound they can emit. Dogs can hear sounds at very high frequencies that humans cannot hear. So a bell around your dog's collar may be makingan unpleasant noise for him that you aren't even aware of.
Pets - Others Logo
Top Pets - Others Experts
Tom Chichester
Ruth summersides
Kardoc
Are you a Pets - Other Expert? Answer questions, earn points and help others
