SOURCE: unlocking my htc wildfire a3333
As you have not specified in particular what is the unlock code required for you, i am giving the ways to unlock all the codes
NETWORK UNLOCK CODE:
You can unlock it by flashing your mobile if your mobile is a CDMA mobile...
The procedure for flashing your mobile is in the link below
http://hubpages.com/hub/How-to-Flash-your-cell-phone
It has an video explanation.
If your mobile is not an CDMA mobile , you can get the network unlock code(NUC) by just contacting the current network provider customer care department.It is free of cost.
The restriction code can be got from your old service provider..This restriction code is kept to prevent someone who stole the mobile from using it with another provider...
They will have a security check done with your date of birth etc..to verify whether you are the exact owner of the phone..
After that they will provide you the restriction code to unlock it and use it with another service provider..
It is all free of cost do not pay anyone for this seeing some advertisement over internet . That is all fake ads.
The above procedure works and you can verify that by seeing the rating of an happy customer here..
http://www.fixya.com/support/t4979448-need_unlock_motorola_razor_v3_from_optus
PUK CODE:
PUK code can be given only by your service provider which is specific for each and every mobile number.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no. If you cant contact through your phone get some other phone and contact them.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software.
Go to the below link and you can confirm that the above procedure works and there is a testimonial given by the customer too. http://www.fixya.com/support/t3079596-sking_puk_code
PIN CODE:
HI If you are asking for pin contact your service provider , he will give you a default pin .
If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Do not try PUK(new pin code) code many times or else your sim will be blocked and you will need a new sim.
SECURITY CODE:
If it is lost nothing can be done. You need to flash your mobile at an authorized service center which will reset the mobile memory and also all the data inside the mobile will be lost.
A helpful rating and an testimonial would be greatly appreciated if you are satisfied with the solution i have posted.
SOURCE: Does HTC wildfire a3333 support
YES IT SUPPORT 3G SERVICE, IT SHOULD BE ACTIVATED BY YOUR SERVICE PROVIDER
Testimonial: " Thanks"
SOURCE: hi, i use htc wildfire
The video calling applications only worl if you have a front camera on your phone, but third party apps like skype may support your main camera.
SOURCE: the HTC Wildfire A3333 phone,
You can download and print the instruction manuals in PDF format by clicking these links:
User Manual
Quick Start Guide
Adobe PDF Reader is required to view the manuals. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
SOURCE: how to install application on
go to www.mobile9.com ,there you will find desired applications, games, themes, ringtones, wallpaper just choose the correct phone model from the given list.
Trying to download it from google play?
i downloaded whatsapp from google play but it didnt work out in my phone
