Question about Sharp Office Equipment & Supplies
My photocopier sharp AR 5516 is showing H4, what is the solution?
Posted by olamilosoye peace on
Naseeb ahmer
    New Friend:
Hi guys , thnaks for u solutions I also have the h4 code on the display of my sharp 16 machine but I saw ur feedbacks do espicially BOTEZ ADRIAN'S one, so do you mean I hold the keys at once or I Press one by one? Thanks
Posted on Apr 17, 2017
DO GANGMIN
    New Friend:
Hi. I have same problem too.
But I already try to do same method. However I cannot get solve this problem.. So how can I do next step?
Thanks, Mark
Posted on Nov 26, 2015
Steve Butterworth
  • 938 Answers
There's an earlier response to this question on fixya in Dec 4, 2012. Search "sharp ar5516 error code h4". It's the third hit down.
Posted on Jul 09, 2015
1 Related Answer
Anonymous
  • 28 Answers
SOURCE: i have photocopy sharp ar-5516 and when i switch
Perform the following procedure to enter the simulation mode.
"#" key Interrupt key "C" key Interrupt key
press 14 and start key twice.
copier should restart normaly.
If not, then you have problems with the fuser, contact me to tell you what you have to do next.
Regards,
Adi
Posted on Nov 05, 2010
Testimonial: "thanks a lot it was very helpful"
My Printer is displaying an H4 error
The error code H4 means that you have a problem with the fixing unit. It could one of the item's > The thirmistor or thermal fuse or the fixing heater lamp
Oct 05, 2012 | Sharp Office Equipment & Supplies
Sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
Sep 02, 2012 | Sharp AR-5316 Advanced Digital Imager...
Ma photocopieur shar 5516 marque un message d'erreur H4
H4 error indicates the fuser is faulty and should be replaced.
Jun 19, 2011 | Sharp AR-5316 Advanced Digital Imager...
I have photocopy sharp ar-5516 and when i switch it on shows (h4) sign
Regards,
Adi
Nov 04, 2010 | Sharp Office Equipment & Supplies
Solution TO sharp photocopier ar-5516 4 H error
Press the following buttons fast: #, interrupt, C, interrupt, C, 14, Start button.
Oct 06, 2010 | Sharp Office Equipment & Supplies
Problem for Sharp AR-5320 Black and White Copier Ar 5516 display H4 error?
for AR 5320 just check 1- main corona 2- leveling the developer unit 3- clean cleaning plate,
for H4 just rest the machine as mentioned above, if not plz check fuzing unit -- thermostat
Aug 22, 2010 | Sharp AR-5320 Black and White Copier
Sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
SHARP AR M-205
Hello sir; this error code require reset the procedure as follow;
1, press "#", "interrupt", "clear", "interrupt".
2, enter 14, press start.
3, turn power off and back on
Feb 07, 2009 | Sharp AR-M205 Copier
Error Call for Service H4-00
# - intrrup key - clear - interrup key 14 print
this all
check fuser lamp, thermost
just
Aug 18, 2008 | Sharp AR-M207 All-In-One Laser Printer
273 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
