Question about Nordic Track Nordictrack 33000 Exp 1000i Treadmill Motor Control Board
Motor overheats shuts off after 30 min...how do i fix problem
johnny rebel
    Top Expert:
  • 10,875 Answers
Use some canned air to clean it
Posted on Jul 09, 2015
My dryer turns off with 30 mins left and the takes a while before u can start it again any hints as to what the problem is would be greatly appreciated model 5030D
Some dryers with a moisture sensor can be eiter have a defective moisture sensor or it called be block with fabric softener.
Outside of this, A friction problem or a drive motor problem could be causing the motor to overheat and shut down. With the dryer empty, try rotating the drum in a counterclockwise direction. Although you should feel some resistance of the belt and motor pulley, it should spin without excessive force needed. If you detect rubbing or unusual resistance, then a friction problem is likely causing the motor to overheat. Excessive lint in the bottom of the dryer cabinet around the motor could also cause it to overheat and stop. A failed drive motor could also be causing your problem
If you do not feel comfortable in accessing the internal dryer components, then I recommend calling a service technician to diagnose and repair this failure. Without a model number I am unable to provide you with specific information. For further assistance resubmit your question with the complete model number of your dryer.
Sep 21, 2016 | Dryers
GE electric dryer 1 year old
The heating element could be failing, causing automatic shutdown.
Oct 17, 2017 | Dryers
How to fix overheating issues when playing games
you should have proper ventilation on your pc or buy special PC Casing that has cooling system specially on high end pc's.. hope this help.. thank you.
Jul 18, 2012 | Acer Aspire AZ5600U1352 (PWSC902039) PC...
Why my treadmills shuts off after 30 min
1) LUbe the deck belt, the lack of lube produce Shut down, by enough friction between deck vs deck belt
2) Lube the rollers bearing very well
3) Measure the input voltage motor, if there are the motor need repair
4) Measure the output voltage board, for input voltage motor, if there are Not the board is faulty.
5) Run the software calibration, for diagnose, and troubleshooting.
God bless you
Jun 09, 2012 | Exercise & Fitness
I wired up my replacement fasco motor for my condenser fan and it ran for maybe 30 mins and shut down. It was very hot and wouldn't come back on until it cooled down. I wired it like the dealer told me,...
Tough to answer without more information. Most likely the speed of the motor is too fast for the fan which causes unnecessary load on the motor causing it to overheat and shut off. Likewise the motor could be underpowered causing the same thing. I would bank on speed. The squirrel cage blowers have speed limits and won't go any faster regardless of how fast the motor can turn. Check the speed rating on the old motor and compair it to the new one.
Sep 07, 2010 | Heating & Cooling
My Frigidaire electric dryer GLER341AS2. The
Does it shut down completely? If it does, and the timer ceases turning, your problem may be a blocked vent pipe or Lint buildup.Your high limit switch is designed to kill power to your heater coils and sometimes the motor in case of overheat.
Mar 09, 2010 | Frigidaire GLER341A Electric Dryer
Gas dryer runs for 30 mins then shuts off.
This is a common problem that is not a good one. But the motor is goin bad. If you try to start it you will hear like a hum then start. Motor is going bad and over heating and shutting down on overload. Sorry. Hope this helps.
Jan 31, 2010 | Kenmore Dryers
Dryer runs & heats,but after 1 or2 cycles it will not start,the start button will just buzz. I ran it for 20 minutes without anything in it.when i shut it off it would not start again. I let it sit for...
The high limit just shuts off the heating element, so that wouldn't determine if the dryer runs or not. normally if the dryer wont turn on after you have run it then will restart after it has been off for a while it usually means that the motor is overheating and what is happenning is the motor has a limit switch on it that shuts the motor off when it gets too hot. It is a resettable switch, so when the motor cools down it will restart. The only way that the motor overheats that much is either a bad motor or something causing enough drag on the motor to cause it to overheat but normally if something is causing drag on the motor, such as a bad roller,blower wheel ect., the belt ususally takes a dive too. All that to answer your original question about the high limit, most likely not.
Dec 16, 2009 | Dryers
Dryer runs for a few mins. then shuts off and turns on after a while
Hi, The motor is overheating and shutting off on an overload.
The motor will need changed. Let me know if I can assist you further.
Vic
May 30, 2009 | Dryers
Kenmore Dryer 90 Series shutting down. overheat?
Your motor is very likely overheating and needs replacement. A simple test is the motor will be so hot you cannot even touch it. Hope this helps!
Jan 05, 2009 | Kenmore 62602 Electric Dryer
Nordic Track Nordictrack 33000 Exp 1000i Treadmill Motor Control Board Logo
153 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Marvin
Marvin
Jesse Garza
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
