Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the relative post easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
SOURCE: remote control code for magnavox dvd/vcr combo
I need codes for my Universal Philips Magnavox remote for a Sanyodvd vcr combo ?
SOURCE: LOOKING FOR THE INSTRUCTION MANUAL
Toshiba 000, 048, 049, 071, 072, 073, 105, 109, 117, 118, 160, 161, 162, 190, 201, 207, 283
SOURCE: my universial remote will not program
you need to go throw all of the codes and you need to make sure you are doing it right to i have had troble with them before
SOURCE: i need the code for RCR311S universial remote to
Step 1: Press and hold the device key (TV,
VCR, SAT, etc) you wish to program. The illuminated ON/OFF key(*) turns
on and remains on. If you release the device key at any time during the
Direct Code Entry procedure, the illuminated ON/OFF key blinks 4 times, and the process is exited.
Step 2: While holding down the device key,
use the number keys (0-9) on the keypad to enter your equipment's code.
While you are pressing the numbers, the illuminated ON/OFF key turns
off.
Step 3: After the 4th number is entered, the
illuminated ON/OFF key turns on. At this time, release the device key.
If the illuminated ON/OFF key turns off, you have entered a valid code
and have followed the correct procedure. If you enter a code that is
not in the Code Lists or you do not follow all of the correct steps for
Direct Code Entry, the illuminated ON/OFF key blinks 4 times when the
component key is released - an indication that a programming error has
occurred. In that case, repeat the process from Step 1 and try the next
code in the list.
Step 4: To confirm that remote is programmed
with the correct code for maximum functionality, test it. If some of
the features of your equipment do not work, try programming the remote
with a different code in the list until you find the code that allows
the remote to control the majority of your component's functions as
different codes can provide different levels of functionality.
* some models like the RCR450 have a LED indicator light in place of the illuminated ON/OFF key.
i hope this would work for your remote controll please contact me if it does
