Question about Konica Minolta Bizhub C350 Digital Copier, Printer, Scanner With Mail Box 350 C
Steps to install c350 and the drivers
Including Scanned and Fax set up
Posted by Leo Steel on
Mister Danger
  • Konica Minolta Master
  • 5,631 Answers
Your Konica Minolta Bizhub C350 Digital Copier, Printer and Scanner should come with a CD/DVD which includes the drivers for different operating systems AND a PDF fie with user's manual. Even is possible that yo may fine several PDF files, in different languages.
So open your PDF file and find the section where it describes with enough detail the steps you should follow . Probably there are different procedures depending the version of Windows, MAC or Linux you are using.
http://kseroimpuls.pl/broszury/en-bizhub-c350.pdf
If you don't hat user's manual, get it from here:
Konica Minolta C350 User Manual
Posted on Jul 08, 2015
Have mx510/512 canon printer/scanner/fax with new windows 10 computer. How do I scan documents or photo into my pc? no scan option when I open canon utility...
Step Connect the all-in-one printer to your computer through the provided USB power cable. Install all drivers that came with the Canon product. Without the drivers the computer is unable to import scanned images to your system.
Step Power on the printer and lift the cover on the top of the scanner bed. Position the image face down on the scanner glass, positioned in the corner when a green arrow points. Close the lid to secure the image.
Step Click the "Start" button, then choose "All Programs," "Accessories" and select "Scanner and Camera Wizard." This is a pre-installed application found on all Windows based computers.
Step Choose the "Scan" option, then select the connected Canon all-in-one printer and click "Scan" again. The image is scanned into your computer with a display of the picture on the screen.
Step Click "File" in the upper left corner of the desktop, followed by "Save." A save window appears on the screen. Title the image, choose a location to save the file to and click "OK." The image file now saves to your computer.
Aug 27, 2017 | Canon Office Equipment & Supplies
Fax solutions software stopped working
Uninstall the Lexmark software including the Fax Solutions. Download an updated driver online at www.lexmark.com and install the updated driver. Once you have installed the updated driver, insert the installation CD to install the OCR and Fax Solutions.
Jun 10, 2012 | Lexmark Prospect Pro205 Wireless...
Installing printer in Linux
Manually Installing a New Locally Connected Printer and Printer Driver When Ubuntu detects a printer it will automatically select a driver if the printer is recognized and a driver is available. To manually add a printer, begin by clicking on the New button in the Printer configuration toolbar. A Please Wait. Searching for Printers dialog will appear as the system is scanned for a locally attached printer. Once the search is complete, the New Printer Wizard dialog will appear including an entry for each detected printer. In the following figure, Ubuntu has detected an HP DeskJet printer connected to a USB port:
Select the desired locally connected printer from the list in the left hand panel and click the Forward button to select the appropriate printer driver. On the resulting screen select the printer manufacturer and choose the model from the list. Click on the Forward button to install the appropriate driver for the printer:
Once the printer driver matching the printer has been selected, click the Forward button and enter the optional printer description and location information. You should be returned to the Printers dialog where your new printer should be listed.
Once the driver is installed you are ready to try out the printer. In the Printers dialog select your printer, right click with the mouse to pop up the menu and select Properties. Click on Print Test Page to send a test page to the printer.
Aug 03, 2010 | Canonical Ltd. Ubuntu
How do I install an hp printer 2110 without a cd onto windows vista computer?
go to www.hp.com
>click on support and drivers tab
>tick on the box that says download sw and drivers
>type in your printer model number then click go
>it will open new window
>select your operating system (vista)
>select full feature sw and drivers
>downloaqd and save this in your pc
>after downloading run the sw and install it on oyur system
Sep 28, 2009 | HP DeskJet F380 All-In-One Printer
WE are looking for a Mac driver for the konica c350 that will work with leopard. Thanks
To save space, drivers are not a part of the package unless you have the printer connected when you install leopard. If you go backwards and either update or re-install leopard it should install the driver for you.
Sep 16, 2009 | Minolta C350 Printer
I want to fax scanned items saved to computer
hi
check if you have the HP solution center softare installed
this software allows to set the fax settings
you can also try the fax wizard or the printer's fax icon for the same that you will find in the control panel---->printers and faxes
Jul 14, 2009 | HP Officejet J5780 All-In-One InkJet...
I can't print from IMac to konica-minolta buzhub C350
Go to konicaminolta web site and download a mac driver. and install it to Imac. Make sure to download OS10.4 or higher.
May 11, 2009 | Minolta C350 Printer
I am unable to send faxes or recieve faxes
Please follow the steps given below to check wheather the error correction is turned off.
You need to disable "Error Correction," please follow the steps given below:
1. Press "Fax Mode."
2. Press "Menu."
3. Press "Up" or "Down" Arrow button repeatedly until "Ringing and Answering" is highlighted.
4. Press "Select."
5. Press "Up" or "Down" Arrow button repeatedly "Error Correction" is highlighted.
6. Press "Right arrow" or "Left arrow" button until "OFF" appears.
7. Press "Select."
Please follow the steps given below to recieve the fax:
1. From the control panel, press "Fax Mode."
2. Press the "Menu" button once.
3. Press up or down arrow repeatedly until "Ringing and Answering" is highlighted.
4. Press "Select."
5. Press up or down arrow repeatedly until "Pick-Up On:" is highlighted.
6. Press left or right arrow to choose an option.
7. Press "Select."
If you want to set a schedule to turn "Auto Answer" "on" or "off:"
1. Press up or down arrow repeatedly until Auto Answer Scheduling is highlighted.
2. Press left or right arrow until "On" appears.
3. Press "Select."
4. Press down arrow button to select the time for "Auto Answer On."
5. Use the keypad to enter the date and time. Press 1 for AM, 2 for PM, or 3 for 24-hour mode.
6. Press down arrow button to select the time for "Auto Answer Off."
7. Repeat step 5.
8. Press "Return" button to save the settings and exit the menu.
9. Make sure the "Fax Auto Answer" light is on.
When the number of rings you set is detected, the printer automatically receives the incoming fax.
To scan a document, please follow the steps given below:
1. Go to "Start," "Programs," Lexmark printer, "Lexmark All-in-One Center."
To see how an image will look after it is scanned, click "Preview Now."
2. Click "Scan," "Send scanned image to."
If scanning an image, choose a graphics program such as "Lexmark Photo Editor," "MS Paint," etc.
If you wish to "Scan to OCR," choose a text program such as "MS Word," "WordPad," etc.
Once the image is scanned, the "Abbyy OCR" software will open automatically.
3. To begin the scanning process, click "Scan Now."
4. To view the additional options, click "See More Scan Settings."
To indicate what type of image is being scanned, select the "Option" next to the type of object you are scanning. Your settings will be optimized for that object type.
To indicate how the scan will be used, select the relevant option from the menu. Your resolution and other settings will be optimized based on your selection.
5. To revert back to the normal All-in-One main page, click "Hide Extra Scan Settings."
6. Under "Display Advanced Scan Settings"; you can see change settings, which will affect the outcome of your scan.
Mar 21, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Hi, Remote Fax Error being displayed
NOTE this option may vary to printer try USING OPTIONS TO SET CHANGES
To resolve the problem, try the steps below. After each step, try to send a fax again.
1. As some fax machines are not capable of receiving color faxes, legal size faxes, or faxes at 200x200 dpi resolution, make sure you are sending an A4 or letter size (not legal size) page at standard resolution:
* Press the Black button for a black-and-white fax. Press the Quality button to check the selected resolution.
2. Make sure the All-In-One has enough memory free when you want to save the scanned documents into memory before sending the fax. Please refer to the following document: Click here to link to the relevant document.
Note: The scanned documents will only be saved in the memory before the whole fax is sent if the Scan Before Dial option is turned on. (This is the factory default.) Up to 50 black-and-white fax pages can be stored in memory at standard resolution when there are no pending faxes in the queue.
3. Turn off the Scan Before Dial option by pressing the following keys on the operator panel:
1. Press the Fax button, then press Options untill u see ADVANCED FAX mode.
2. Press Select.
3. Press Options nine times until SCAN BEFORE DIAL appears on the LCD display.
4. Change the setting from Yes to No using the + (right arrow) button.
5. Press Select.
Note: The Scan Before Dial option controls whether a document is scanned before a call is dialed. This parameter only applies to a mono fax that uses either 200x100 or 200x200 resolution. Higher resolution mono faxes and all color faxes are scanned after the call is dialed and the receiving machine's capabilities are known.
4. Lower the fax transmission speed 9600 bps, as some older fax machines are not capable of receiving a fax at a high speed. To do so:
1. Press the Fax button, then press Options untill u see ADVANCED FAX.
2. Press Select.
3. Press Options untill u see until MAX SEND SPEED appears on the LCD display.
4. Change it to 9600 BPS using the - (left arrow) button.
5. Press Select.
5. Turn off ECM (Error Correction Mode) by pressing the following keys on the operator panel:
1. Press the Fax button, then press untill u see to get to ADVANCED FAX.
2. Press Select.
3. Press untill u see ERROR CORRECTION appears on the LCD display.
4. Change the setting from On to Off using the + (right arrow) button.
5. Press Select.
Nov 16, 2007 | Lexmark X4270 All-In-One InkJet Printer
Konica Minolta Bizhub C350 Digital Copier, Printer, Scanner With Mail Box 350 C Logo
136 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
