Question about Motorola Radio Communications
Motorola BPR 40 will transmit,but not receive through the microphone. Works fine as a handheld
Posted by Ransom Eskridge on
eradiostore
  • Motorola Master
  • 1,658 Answers
You may have one of three problems: Your audio accessory jack is bad, you are using the wrong mic for the radio, or your mic is bad. Try the mic on a known good BPR40 and if it test good, if so, your BPR40 with the problem needs a new audio accessory jack. (Repair is available for this model.) We have found the BPR40 will only work properly with the remote speaker mic designed for it, despite some other Motorola mics appearing to fit the jack. Construction grade mic PMMN4013 is a good option, as is the lightweight PMMN4077.
Posted on Jul 25, 2015
3 Related Answers
eradiostore
eradiostore
  • 1658 Answers
SOURCE: my customer has 6 motorola max trac vhf radios.
If this is a new install, it is likely noise from the vehicles electrical system scrambling the processor of the radio. Put a filter on the power leads and check your install.
Posted on Aug 31, 2009
Anonymous
SOURCE: need a free download of an operating manual fo the
I need a service manual of motorola T 5417 A ,. I hope you can help me . Thanks a lot
Posted on Nov 07, 2009
eradiostore
eradiostore
  • 1658 Answers
SOURCE: Can Receive but not Transmit
1) Double check your interference code eliminator and the Qt filter. Make certain they are all set identical.
2) If you are still having trouble, shut off the Qt filter.
3) Then if you still have trouble shut off the code. (Off is sometimes "zero" or "n" for no.)
4) If the above steps do not help you have either a defective radio, or a bad battery. Switch the batteries out of the working units to the non-working and see if the problem switches to the other units. If so, replace the battery packs. (Note: it takes more battery power to transmit, so the problem would first show up in the transmit area.)
Best regards.
Posted on Nov 10, 2009
Testimonial: "Response from this site is almost immediate! Will try it out & respond asap ... although I must say I dont understand those techie terms:{ TQ anyway!"
My voice does not transmit through the earpiece
Sounds like you have a problem with your microphone.
Please contact us.
Mark
Motorola Support
CONTACT US
Jun 04, 2014 | Motorola Mobility H710 Bluetooth Headset
I have the AKG wms 40 dual mini mic set with two wireless mics. When mic on ch 2 is in the off position, I get lots of static. Works perfectly fine when on. What do you think is the issue?
Channel 2 mic's receiver needs the Squelch adjusted. The squelch control mutes the receiver so that when the transmitter stops transmitting, erroneous noises are not picked up and amplified.
Jan 23, 2013 | AKG WMS 40 Professional Microphone
One of my walkie talkie's transmits but doesn't receive...WHY?
Your speaker is blown. The microphone still works but you can't hear any audio. Take it back if there not to old.
Nov 01, 2012 | Motorola TalkAbout T6530R (14 Channels)...
I have an almost new Midland 75-822 that the WX works fine on, but the CB doesn't seem to receive, or transmit. It operates normally, but no reception, and no evidence of transmissions.
you'll need a schematic and some knowledge. there a two diodes that control the rx and two that control the dx.Check them to make sure they are producing the correct power out put if they are not you should replace all 4
May 10, 2012 | Midland 75-822 40-Channels Handheld CB...
I am from argentina, i have a problem in one radio motorola T9500. No receive (one second received 1 meter distance) but transmit any problem. A "tecnhical man" say me, I need load codes in the...
Have you tried receiving with a EARPHONE? The speakers in these units are VERY poor and do fail easily.
IF the earphone works(!) try a external SPEAKER/MIKE instead of trying to find and install a replacement speaker!
See the link below!
$8.99 US
Anthony
Speaker Microphone for Motorola talkabout T5022 T9500 T280 T270 T5800...
Dec 01, 2017 | Motorola Talkabout® T9500 Two Way Radio
My cobra 19 Dx if it receives the signal of another person, but it does not leave the my signal voice, is listened to when preciono the microphone a noise just.
If I understand you can receive but not transmit. Try replacing the final transistor in the rear of the radio and see if that works.
Feb 16, 2011 | Cobra 19 DX III 40-Channels Base CB Radio
Need a free download of an operating manual fo the motorola bpr 40
Nov 07, 2009 | Motorola Radio Communications
Stops working when I try to transmit.
problem may be the button loose connection to the main board...we can fix these radios. cb shop temple, tx on yahoo search. The button is connected in so it controls both sections.
Aug 03, 2009 | Cobra 75 WX ST 40-Channels Handheld CB...
Shure wireless UHF microphone
Make sure the microphone and the receiver are still broadcasting/receiving on the same channel.
Check that all of the appropriate connections are right from the receiver to the mixing board are connected as well.
I hope this helps!
God Bless you!
Oct 17, 2008 | Dual Pro2- WM795V Channel VHF Wireless...
Maxon Model MCB10A
In order to test this unit you will need a power meter with a dummy load. connect the power meter and turn on the unit, key the microphone and look at the power meter it should have a reading of < 4 watts PEP unmodulated and = 4 watts PEP modulated. If you do not have this reading the RF transmitter in the CB might be malfunctioning. You will need a RF generator, a power meter with dummy load, oscilloscope and a multimeter to troubleshoot this problem with. If you do not have or do not know what this equipment is or how it works, please take your unit to a CB repair shop. Thank you, Shuttle83
Oct 05, 2007 | Maxon MCB-40 40-Channels Handheld CB Radio
Radio Communications Logo
229 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Muntejaya Ginting
Muntejaya Ginting
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
