Question about Janome Sewing Machines
My sewing machine QC 200 by Janome suddenly stop working.On the screen I have error message E3
I was showing machine to 2 different repair shop and had 2 absolutely different diagnostic for this problem. Both are very expensive to repair (motor or boards) I completely confused! Could you please help me to understand what should I do with my machine!
Posted by Marina R on
Greg Hoffman
    Guru:
  • 147 Answers
Check your needle alignment
Posted on Jul 12, 2015
5 Related Answers
Anonymous
SOURCE: Janome Memory Craft 4900 QC
its the sensor on the bobinwinder who are loose. If you are handy. you can remove the top cover of the machine.
And on the left side of the bobinwinder you will find a micro switch. Probably you have to tighten the screw on it..
Posted on Feb 20, 2008
Anonymous
SOURCE: machine will not complete a buttonhole, keeps showing error code 6L. No error code listed in manual. Machine will only do first half of buttonhole and then shows code and stops.
I've been looking too and I found here http://sewing.patternreview.com/cgi-bin/sewingclasses/board.pl?t=18328that you need to put the bar behind the needle threader down. I think they call it a button hole stop? I don't know, but it worked. I didn't even know it existed. But it solved my problem. On my Kenmore it looks like a black lever and you pull it down. It tells the button-holer that you are at the end of the hole and it needs to backup. nifty, kind of.
Posted on May 27, 2009
bargainbox
Hassy
  • 1388 Answers
SOURCE: Janome E1 error
If a warrantee job, it will be no charge.
Motor in Australia is $149-00.....plus installation charge.
You could phone or email Janome HQ or another dealer in your country and ask for an explaination of the E1 error to satisfy yourself of what is the likely cause, and a quote to fix it.
Posted on Aug 23, 2009
ken dourof
  • 980 Answers
SOURCE: Motor for Sewing Machine
you will only get one from a Janome or New Home dealer or direct from Janome
Posted on Oct 28, 2009
marianne bags
  • 161 Answers
SOURCE: My Janome memory craft 8000
step motor error may mean the embroidery arm is out of position gently push it back home towards the machine and see if this helps. If the mother board is gone, they will not be able to replace it as its so old, but you may be able to get an 8000 or 9000 on ebayso you can still use your discs if you don't want to get a new machine
Posted on Sep 11, 2010
Bobbin winder is engaged and shows up on screen correctly, but sewing mode is still engaged and bobbin winding keeps stopping.
check the drive knob on the end of the machine
it should be loose when winding a bobbin
if it is tight or seized then that will drive the needle
Sep 20, 2015 | Janome Sewing Machines
What does E3 error code on Janome MO 200 sewing machine mean?
If you do not have your user's manual, you can purchase another one at several sites for a nominal charge, and download it immediately. I would recommend that you have one, and keep it near or under your machine.
You can also contact Janome customer service, either by email or phone, and here's the link: Janome Contact Us
Sep 13, 2014 | Sewing Machines
Memory craft 5200 showing error 3
If your user manual doesn't tell you, and your dealer doesn't know,
you can go to the Janome website, go to tech support , and they can answer your question.
DO NOT use your machine until you get the error corrected.
Apr 10, 2013 | Janome Memory Craft 9000 Computerized...
Janome 4900 sensor problem?
Maybe the bobbin winder is in the the on position. Push it to the off position.
Feb 08, 2010 | Janome Sewing Machines
I have a Janome 1600P QC drags on a Little Gracie 2 frame
Sorry for your headache. It is the frame. If it is not level, balanced, you have hell to pay. Also it there is a nick in the grooves of the carriage tracks this will cause a machine problem. You may be able to repair the frame, or level it about the old level the table trick, put something under that part.
Good luck
Sep 06, 2009 | Janome Sewing Machines
Try this link for an affordable solution to repairing your Janome MC 8000 Display Back.
https://sew-bright.com/products/janome-memory-craft-8000-lcd-backlight-replacement-kit
Oct 28, 2008 | Sewing Machines
Janome 6600p: E1 error
Hi
Direct from the Janome workbook E3 error relates to:
"Stepping motor for tension release (MC6500P & MC6600P only)"
Ensure there is no lint or thread trapped between the discs of the top tension unit.........try "flossing" where thread goes down thru tension unit with a scrap of clean fabric.
It may also be the mechanism that releases tension when the presser foot is raised....it is a sensor and may be out of alignment...not really an easy home fix.
Let me know how you get on, just remind me of the issue as I respond to many.
Bargain Box
Oct 08, 2008 | Janome Sewing Machines
Error 5 on my machine
Can I get a copy of the instruction manual for your Janome Harmony 2049? I got my mom's machine when she passed away in Dec but no manual. Thank you!
Jun 28, 2007 | Janome 2049LX Mechanical Sewing Machine
Sewing Machines Logo
134 people viewed this question
Top Janome Sewing Machines Experts
tina gallow
Lee Hodgson
Lee Hodgson
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
