Question about Electrolux Frigidaire Gallery FGHB2844LF 27-8 Cubic Ft French Door Refrigerator
Ice maker making huge chunks of ice - Electrolux Frigidaire Gallery FGHB2844LF 27-8 Cubic Ft French Door Refrigerator
Posted by Cheryl Altom on
Won't pump water to tray.
How a Portable Ice Maker Works - NewAir
www.newair.com/articles/how-a-portable-ice-maker-works/
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
https://www.walmart.com/reviews/product/15162429
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker - Walmart.com
www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
Walmart
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
Jan 31, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
Franklin chef ice maker fim70 finished running cleaning cycle. have cleaned plugs, lines, on rear and sprayer inside bin. water continues to run, ice forms on top (w/ frost). Ice never drops.
Hello
Ice may jam up in an ice dam and close off the chute. Shove the ice scoop up into the chute with a fair amount of force to break up the ice dam. Chunks of ice should fall into the bin, followed by a shower of ice cubes.
Jun 21, 2011 | Franklin Freezer Chef FIM70 Commercial Ice...
Ice maker is overflowing
Older icemakers have a bar that drops from above your ice bin; once the bin is full the bar is raised and trips turning the ice maker off so that it won't dump. If your's is this style, try manually pushing the free end of the bar upward so that it locks in the upward position. Newer ice makers with the ice bin in the door have a small panel that moves to the open position when the door opens and closes when the door closes. Mine also includes an optical sensor that is visible when this panel is in the closed position. Try placing a non-clear tape over the optical sensor (don't know if that will work or not but worth a shot). If effective in stopping the ice flow then call a repairman. If none of this works, turn off the water supply coming out of the wall to your freezer.
Sep 08, 2009 | Kenmore Freezers
Leaking ice maker
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze diverting the water. You can take the water line off the valve and watch to see if it drips.
Aug 30, 2009 | Freezers
Kenmore ice maker problem
the problem is an unlevel icemaker to prove this do you see little droplets of water freezing from the icemaker or a remote possibilty is do you have to an R/O system and have you change the filter if unit has one.
Aug 19, 2009 | Kenmore Freezers
Frost buildup in frost free freezer
There is a defroster built into the ice maker to melt the ice a little around the edges before dispensing on most ice makers it may need replacing.
Jul 28, 2008 | Freezers
Ice maker leaks into the ice storage bin
turn off the power to the appliance and apply a hairdryer to the ice maker compartment for about 2 mins , worked for me.
Jan 11, 2008 | Freezers
Something wrong with Harvesting cycle, ICE will not come out, coils freeze up.
If you need answers and have not recieved results I will try to help, I see no one responded to your request because the manual and diagnostics info seems to only be sent to people that sell and purchase the machine. If you need help and want answers  you can call me at 864-812-1887 or e-mail me at [email protected]  your description of the problems could be many different possibilities. I want to know and help also. Thanks John Tripp
Sep 03, 2007 | Hoshizaki Commercial Freezer KM-500MAH
Electrolux Frigidaire Gallery FGHB2844LF 27-8 Cubic Ft French Door Refrigerator Logo
101 people viewed this question
Top Electrolux Freezers Experts
Dennis Boxerman
Vernon Taylor
Are you an Electrolux Freezer Expert? Answer questions, earn points and help others
