Dear sir mam
i forgot the lock code that i had changed. i have already tried with all the possible lock code i could have kept but none worked. please help me. i will be very thankful to you.
i forget my lock code in my mobil(n70)i forget my lock code in my mobil(n70)
AnonymousFeb 25, 2008
i try all the possible code number that i entered as i remember but until now it doesnt work. please help me and thanks a loti try all the possible code number that i entered as i remember but until now it doesnt work. please help me and thanks a lot
AnonymousJun 12, 2008
i hav forgot my lock...is there ne trick to get it reseti hav forgot my lock...is there ne trick to get it reset
I tried 3x to enter my code,but its locked already & I cannot open it anymore.pls help meehh!!!thanks!!!I tried 3x to enter my code,but its locked already & I cannot open it anymore.pls help meehh!!!thanks!!!
You cant do it with yourself,but your problem is very easy to solve,just go to the cellphone repair shop nearest in you & tell them what happen.dont worry mura lang yan.50-100peso lng...kpg sobra p dyn yung siningil sayo try ka sa iba..,gudluck
Dear sir mami forgot the lock code that i had changed. i have already tried with all the possible lock code i could have kept but none worked. please help me. i will be very thankful to you.
Please do not use the codes displayed on various websites.You may end up
losing your phone. Just take it to Nokia Care they will help you in
resetting your lock code and that is chargeable.
Sir, there is an application that can retrieve the security code. The name of the application is "unlockme". Once downloaded, install it to your phone and run it. Wait for a couple of minutes because the software is retrieving it.
use this master code *#7328748263373738# it will change/reset your code and then if it again asks for the code then remember by default the code is 12345.
Hope this solves your problem.
remove your sim card and memory card, then, press #3 button,* button,call button and power on switch at the same time for about 10 seconds, then wait untill it reboot... then its done no more unlock codes.
note: this process may erase all your data such as photos,videos,contacts,msgs etc.
but this tip can remove unlock codes
SIM pin code: This is a pin code that locks the sim card until you enter the correct code. This protects your account, even if your sim is put into another handset. To reset it, you need the PUK code: Pin Unlock Code (PUK) If you miss keyed (or forget) your SIM PIN code, and enter the wrong one 3-5 times in a row, the sim will lock up, and you’ll need to enter the unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
help me
forgot of my lock phone code
[email protected]
