Question about Sony Playstation 3 (PS3) Console
Corrupted files, how do you repair?
When signing on system states that the last three game files are corrupted. deleted the corrupted files. the game will still not create a new file. what to do?
Posted by Tammy Hobby on
Matt Weaver
    Master:
  • Sony Master
  • 665 Answers
Can you still play the game ok? If the game you are trying to play wont start up, then the disk could be damaged. If it is downloaded content, then the file could be corrupt and require a more stable connection to install.You may have to delete everything about the said game including offline files to reinstall. Good luck, and I hope this helps.
Posted on Sep 11, 2015
5 Related Answers
early1234
earl norman llanera
  • 871 Answers
SOURCE: Playstation 3 hard disk files corrupted???
hey ash,
ps3 Hard drive needs to be manually reformatted and checked for bad sectors.
as what youve said, you already formatted it and yet it still says there is a corrupt system file.
when i say "manually formatted" you have to clearly take the hard drive out and format it using another pc or ps3.
Posted on Jun 03, 2008
Anonymous
SOURCE: My PS3's hard disk file system is corrupted
There is an alternate way to restore your HDD. Turn off your system and when u see the red light, hold the power button in front until you hear a total of 4 beeps (1 alone, 1 alone, 2 together). It usually works on second try. it should show a screen and say hook up controller with a usb cord. Then it should show i think 6 options. Choose the restore option. it should work.
Hope it works and wish you all the best!
P.S.- I just got the 80010514 error on my ps3 and my ps3 games dont work anymore :(
Posted on Jan 07, 2009
Anonymous
  • 64 Answers
This is happening because your console is not recognizing the HDD (hard drive) for what ever reason. The corrupted files are about to do damage to your console, and a PS3 will not turn on if it thinks further damage will occur. Here are two things you can do;
1. Try accessing the HDD reset menu. Here's how you do this: With a solid red light showing, hold down both the power & eject buttons. You're going to hear a single beep, then a double beep. Once you hear the double beep, release both buttons. You'll get a message on your TV saying "connect your controller using USB". Following all the instructions will lead you to a 6 item menu. You are going to choose number 3. If that option doesn't work, pick number 6. BE WARNED!!! Number 6 will delete ALL of your saved memory! I know that really sucks, but this may be the only way to save your console short of repair. You can "back-up" your saved data using a "USB storage device" Like a memory stick or even your iPod.
If none of this works, or the console just won't let you do the "double button" thing, it'll need to be repaired. You can contact PSR repairs at www.psr1.com. They are really great! They do both warranty & non-warranty repair work for a very decent price. I hope I helped. Good luck, Indra!
Posted on May 30, 2009
Anonymous
  • 64 Answers
SOURCE: says corrupt game files; wont let me play
Hmm... You've already deleted everything and re-loaded it, correct? Did you also wipe the "saved game" memory? The bad file could be in the PS3's internal memory card. So, you'll have to wipe that. If this is still not working, you may have to reformat you entire console. I know that really sucks, but it MAY have to be done as a last resort. In the settings menu, there's a place that says "format hard drive". If you try to "back up" your memory on to a memory stick, I'd recommend against it. Because you might just be putting the corrupted file back into the hard drive! Let me know what you decide to do, bro. Maybe I can be of more help down the line. Good luck, Dempsey!
Posted on May 31, 2009
Anonymous
  • 151 Answers
SOURCE: Playstation 2 will not save game "corrupt file"
You can recover the data unfortunately. You may have turned the power of while you was saving or taken the card out while saving the game e.t.c. make sure the savings for guitar hero work, if they do there is nothing wrong with the memory card, just what i have just said.
But you can go back to where you were with Action Reply MAX. they have cheats saed games from all sorts of places on tuns of games, & since you have the slim you can plug in you ethernet cable and download a saved games file to where you were on the corrupt file.
Hope i have been helpful
Posted on Jul 20, 2009
Error80022d11
You have to delete your current user, and then create a new one. This will unfortunately delete your saved games, if you don't backup.
Oct 08, 2013 | Sony Playstation 3 (PS3) Console
Corrupt file on xbox360
You shouldn't need to delete all files. Your profile and savegames are different. You can just delete your profile from System/Storage and remember NOT to choose "Delete profile and items". If you're getting a corrupt profile and you're using a memory stick to save, it's a good idea to get into the habit of exiting any game and signing out before you switch off the console.
Sep 28, 2013 | Activision Video Game Consoles & Games
Xbox live account states "corrupted
Hi. Try this. You will lose any achievements you have earned since your profile went offline.
  1. Power on your 360.
  2. Access the dashboard, go into system settings, then into the memory option. Find your profile.
  3. Delete the corrupted profile.
  4. Sign out of your profile if you're already on it! Press the Xbox guide button press X and select sign out.
  5. Go into "my xbox" on your dashboard
  6. Select "recover gametag" in the dialogue box. Press A to select it. Follow the instructions to repair your profile.
  7. Enter your gamertag in the Xbox live gamertag dialogue box that pops up
  8. When process is completed your avatar will appear in the sign in area of the dashboard
Apr 04, 2011 | Microsoft Xbox 360 Console
When I try to save replay,s on the gamecube game: tony hawks pro skater 3 I have a problem, First i play, then i save a replay,Then i go to main menu, options, load replay, i see a list of all my...
Memory Card Error Messages
Fully Corrupt:
When the entire save area of the Memory Card becomes corrupt, the system will inform the player that the Memory Card is corrupt and offer to format it. The card must be formatted before gameplay begins or when the game attempts to access the Memory Card. The exact message may vary from software to software.
Follow the steps for formatting a memory card.
For specific issues with the Memory Card 1019, please click here.
Suggestion: It is always a good idea to copy your most important files to a second Memory Card as a back-up.
Data Area Only Corrupt:
When only the data area of a Memory Card is corrupt (not the entire Memory Card) the game may not detect this until the Memory Card is accessed. Once it is accessed, the game will inform the player that the file being accessed is corrupt and must be erased. The game will only delete the one file being accessed and will not format the entire Memory Card (Other saved game files on the Memory Card may be OK).
Follow the steps for deleting a file.
Memory Card is Damaged:
If the Memory Card has been physically damaged, or has been damaged beyond repair, you will get this message. The Memory Card will need to be replaced. The system may attempt to format the card, but if it cannot it will give the error Memory Card is Damaged. There is no way to recover the game data from the memory card.
For information on locating replacements for older products, please click here.
Dec 12, 2010 | Nintendo GameCube Console
Gamer tag lost when trying to retrieve it it says not enough memory although there is
check your memory if there is any corrupted files
to check for corrupted files:
1.press the guide button the silver button in the middle of your controller
2.select settings blade and chose system settings
3.select memory
4.check all the folders if there is a corrupted files (corrupted file has a yield sign)
5.delete the corrupted file
then recover your gamertag
Jun 04, 2010 | Microsoft Xbox 360 Console
When I deleted home on my pS3 I got corrupt files
  1. Insert the PlayStation 3 memory card that has the corrupt file into the memory card slot of your PlayStation 3 console.
  2. Step 2 Turn on the PlayStation 3 without a disc in the console or with the loading lid open. A menu screen will then appear on your television.
  3. Step 3 Scroll through the options of the main menu using the down button on your directional pad and press the "X" button when you get to the "Browser" option.
  4. Step 4 Click on the icon that shows the memory card that you inserted by pressing the "X" button. You will now be able to view all of your memory card files. Locate the corrupt file and click on it with your "X" button.
  5. Step 5 Scroll through the list of options that appear and select the "Delete" option by pressing your "X" button. The file should now be deleted. Restart the PlayStation 3 and go back to your memory card to make sure the file was deleted.   NOTE WITH THIS IT WORK PROPERLY....
Apr 15, 2010 | Sony Playstation 3 (PS3) Console
We have three login accounts with ub funkeys. Mine is the only one that will save progress. How do I fix it?
First time I hear from that problem. Please check this path.
c:\program files\u.b. funkeys\radica game\data
you should see a folder named System (dont touch it) and 1 folder for each account you have created, inside the folder there is always a file named profile.rdf, if the file doesn't exists delete the folder and create a new one (in the game).
If the file exists maybe it's corrupt (sorry) delete the folder of the not working account and create it again (from the game enviroment).
If this still not working, copy your working account to some other place in your PC. Remove the software(uninstall), reinstall it a, update your software using the patch001.exe file int he official site and copy again your saved files (with your previosly saved games) in the right place. Hope I can help you.
Oct 19, 2009 | Blue Orange Games Ub U.b. Funkeys Dream...
Says corrupt game files; wont let me play
May 31, 2009 | Sony PlayStation 3 40GB System
A new file - professor layton
The game should, of course, overwrite existing saves without problem
While the game does have a few set save points, the best way to save (which can be done at any time) is to use the Save option in the trunk (some players forget about this)
If you save into a save slot doing this and it's not there when you next restart the game, then something is wrong
If you purchased the game "second hand" on eBay, then you may have ended up with a pirated copy (these have caused various problems for players including stopping during the game)
The game doesn't have an option to delete the save files
If you are confident that saving just isn't working and you're unable to return the game for replacement or refund, one drastic course of action may be to corrupt the save (by quickly turning off the DS while it saves), thus causing the game to say the save is corrupted and make a new save file ... naturally, this should only be done as a last resort
Mar 09, 2009 | Nintendo Professor Layton & the Curious...
Saying saved files are corrupt and must be deleted
My Nintendogs game has done that before; I had a Labrador Retreiver, and I had it for about 3-4 years. Then, it said that the files were corrupted. I had to start a new game all over again. Try that and tell me if it works out.
Dec 28, 2008 | Nintendogs: Dalmatian & Friends for DS
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Daniel Dollive
Daniel Dollive
Steven Wander
Steven Wander
Raj Patel
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
