Question about Integra Dtr-7.8 Receiver
I have a Integra 7.8 it powers up. The problem the sounds cuts out now after 30 seconds or so. Then start making a popping sound in speakers after that. system has been installed for 6 yrs
Posted by jeremy newberry on
johnny rebel
    Top Expert:
  • Integra Master
  • 10,875 Answers
If there is smoking near it then it needs to be professionally cleaned
Posted on Jul 06, 2015
My receiver started making popping sounds and cutting out for seconds at a time. Checked all connections can't figure what's wrong.
It sounds to me like you have a problem with one of the amplifiers and the speaker protection is activating. If you are playing at a low volume setting and this is happening, the likelyhood is that one of your bias levels is out of tolerance. If you don't know what you are doing, get someone who does to check the DC voltage on your speaker outputs without the speakers connected. The bias control should be set to 0 volts on the speaker outputs.
Mar 04, 2015 | JVC RX-6042 Receiver
Cracking and poping with Yamaha surround sound system
Try put a ground line from any metal of your stuff to the any metal direct to the ground. these eliminate noise of the speaker.
Jan 03, 2008 | Pioneer VSX-54TX Receiver
How to fix Integra 7.8 display is dead
They will be value of 10 ohms or less in the secondary power supply attached to the front assembly
Jul 20, 2014 | Integra Dtr-7.8 Receiver
Sound coming from under hood, like pop can bouncing around inside engine
need to check your oil level, how old is your timing belt i do wonder if you havent got a broken skirt on one of your pistons
Apr 30, 2012 | 1997 Acura Integra
I have a 93 integra 1.8. I was driving and it went from 30 to 0 in less than 30 seconds now wont start. there is no fire what could it be help me please I am female and need advice thank you integra...
The first thing I would check is to see if the timing belt is broken. You can do this by removing the distributor cap, cranking the engine, and seeing if the rotor turns. If it does not turn than the belt is likely broken. Usually the engine will sound like it is turning over faster than usually.
If the rotor is turning and you have no spark the usual suspect is the igniter. It is located in the distributor and has four wires going to it. Two of them will go to the coil. Make sure there is power to the igniter and the coil. If there is power than I wouldn't have any problem replacing the igniter. They are a pretty common issue for no spark symptoms.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
May 03, 2011 | 1993 Acura Integra Hatchback
Popping noise from speakers
sounds like the digital input and the component input are casing inteference , try removing the component video and see what happens
May 23, 2009 | Sony STR-DE695 Receiver
Sound problem
Make sure all speakers that are hooked up sound ok. If any of them sound lower then the others or sound distorted you may have a speaker with a partially shorted voice coil. If speaker or speakers pop when power is first applied you may have a grounded speaker that should not be grounded. Each speaker wire rides on 6vdc and if any speaker sees a ground you will have 6v across voice coil which would explain any popping noise when first turned on and radio may play for awhile then overheat. be sure speakers are 4 ohm min per ch otherwise amp will run to hot. Just a few Guesses
Jan 13, 2008 | Denon AVR-1708 Receiver
Popping noise
Does the " popping" noise come through the speakers or from the TV chassis ? If it is coming through the speakers you could have a bad solder joint somewhere in the tuning circuit. If it is a snapping sound coming from the chassis, then you probably have something arcing in the high voltage circiut. If this is the case then you should have it checked out since this can cause other parts to short shutting down you set completely.
Jan 21, 2007 | Hitachi C25-RF35S 25" TV
Integra Dtr-7.8 Receiver Logo
247 people viewed this question
Top Integra Audio Players & Recorders Experts
Andrew Taylor
Andrew Taylor
Larry Stiles
Larry Stiles
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
