SOURCE: Solis Palazzo - dreaded ventilate problem
Hi
Your machine is still in the descale mode. You haven't finished. If you have run the descaler through, the water is ermpty the pump will still keep going until it stop on its own. If it doesn't stop on its own, the computer thinks its still in the descale mode. remove the water tank and turn the machine back on. The pump will run and then make a lot of noise, then stop. This can take up to 5 minutes. Let it run until it stops. You will get blinking lights on the panel. Put the water tank back on and close the steam knob then open it again. The pump will start the rinse mode. Let it stop on its own. Computer can't see that you ran a whole tank of water, but it can see when the flow meter stops that there is no water left. If you have already rinsed the machine start the pump flowing and just lift the tank off. When the pumps stops the rinse cycle the descale light will be gone but you will have the heater light blinking and the water light steady. Put the tank back on and close the steam valve then open it again. This will clear the water light and the machine will start to heat again.
SOURCE: ventilate message, but no air in system
HI Sorry, but that sounds like a bad flow meter. The flow meter is not that hard to replace, with a little common sense, but the new flow meter should be the brass one. There are some tricks to getting the top back on, Pull forward on the bypass doser chute a little so it will center in the opening. You don't have to disconnect all the wires that go to the top. They are long enough that the top will set behind the machine carefully. Remember the tubes that go to the flow meter. You don't want to get them backwards.
SOURCE: Ventilate shows, nothing works
There is an air lock in the hydraulic line of the machine, thats why it is calling for ventilate, if hot water valve is open and it is still calling for ventilate, then it is possible that the valve is blocked, it might be at top of the wand or at the tap rod assembly.
SOURCE: Saeco Royal Professional is stuck on "Ventilate"
Hi
There are possibly 2 things that it could be.
1. Check that the tip of the wand is not plugged.
2. Your solenoid valve that controls the water is bad or stuck. That means a trip to the service center.
SOURCE: saeco royal profesional machine says
Hi.
The machine will stay locked until Ventilate is on.
Try following the indications here: The following procedure works when you get the ventilate error: The Ventilate sign can....
Regards.
Ginko
