Question about Coby DVD938 Theater System
How do I hook up my coby dvd to my blu ray
Want to use the surround sound through my blu ray
Posted by Theresa Wallis on
Wes Cichosz
    New Friend:
  • 28 Answers
There should be an orange rca plug on the back of the blue ray player. That is a digital audio output plug. The Colby has a similar plug. That's the digital audio input. It won't make any difference for the most part what color the your cable is. It could be red or white (one of your stereo plugs of need be). Connect the cable between this two plugs. Viola! (It's wise however to use orange cuz then you could easily distinguish which cable is carrying the digital audio). Make sure that digital audio is selected in your menu.
Posted on Jul 05, 2015
1 Related Answer
Anonymous
  • 93 Answers
SOURCE: can't get surround sound for tv shows
The coby dvd 988 has 2 rca audio input jacks, you need to have these connected to your TV AUDIO OUT jacks, these are usually colored red and white like right and left stereo jacks, be sure to set up the TV for AUDIO output through these connections, some tv`s require that the internal built in speakers are cancelled and the audio output jacks are enabled. Set the coby input signal to receive the port you pluged the tv signal into.
Posted on Feb 06, 2009
We have a new TV, old surround sound, old dvd player & want to get Blu-ray player with component video output to work with our surround sound. Is this possible & Which Blu-ray player?
component video output is not going to help you hook it up to a surround system. component video is just that - video. No audio signal is carried on it. You would be better served hooking your blu-ray player to the tv via hdmi cable and then running an optical cable from either your blu-ray player or your tv to the surround system (assuming your surround system has an optical input).
Dec 24, 2016 | Televison & Video
Hooking up a sony dav is 10 to my 40 inch coby lcd tv
Hi, unfortunately Coby is not manufactured any longer. I have a problem not the same as yours, but I can't use my headphone when using my Panasonic Blu-Ray player. Have to use the sony digital surround sound. nothing comes through the Coby...If you have an extended warranty, I would call and have it replaced with another 40 inch brand..They can't fix it.I'm calling to have mine replaced or repaired...sorry i couldn't be better at helping..
Jul 05, 2014 | Coby 40 TFTV4028 LCD TV
Plying blu ray, voices not reproduce only surround channels!
Make sure you have a center speaker hooked up as most voice tracks come through the center channel.
Jul 12, 2013 | Televison & Video
I just bought a Blue Ray player but my surround sound has a dvd player built in and only one input which I have my new Sharp TV plugged into. How can I hook up my Blue Ray . I have the HDMI cables
Depending on if your surround system has a hdmi input or not. if it does you can connect the blu-ray player to it. If it doesn't have an hdmi input you will have to run the hdmi cable from the blu-ray to the tv then run a set of rca cables (red and white plugs) from the tv audio out to the surround systems' audio input jacks to get sound through the surround system. Most surround systems don't have an auxiliary input for another video device.
Nov 21, 2009 | Onkyo TX-SR606 Receiver
Blu ray connect to my sc-pt660
as far as hooking up your blu ray player to the sc-pt660, the only real way to utilize the surround sound (with true surround sound) is through the optical audio out. You need to connect your blu ray player through hdmi to your tv and then connect your blu ray player to your surround sound using the optical audio out/in. I, personally have the sc-pt660 hooked up through component cables so I don't waste an HDMI input on my TV. Except for cd's, there is no reason for you to use the actual dvd player part of the surround sound considering you have a blu ray player. In conclusion, hooking your blu ray player and the sc-pt660 up to get better video simply isnt possible (your blu ray player alone gives the best possible resolution, 1080p). As far as audio goes, run an optical audio cable from your blu ray player to your sc-pt660 to get true surround sound.
Mar 23, 2009 | Panasonic SC-PT660 Theater System
Move and can't find manual for the surround sound/dvd 207
http://www.cobyusa.com/files/manuals/DVD207_MN.pdf
Jan 06, 2009 | Coby 0946 DVD-207
Cannot get digital output
Digital output is for the reproduction of 5.1 or higher surround sound.  Though it will support 2.0 audio it is not meant to be hooked up to a tv, but meant to be hooked up to a surround sound reproduction device.
Jan 06, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
Does remote have audio volume adjust?
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Unfortunately, the dvd 224 doesn't have a volume adjustment. The models that do are the ones that come with 5.1 surround sound speakers such as dvd 755, dvd 937, and dvd 958 just to name a few.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Dec 20, 2008 | Coby DVD-224 DVD Player
Coby DVD938 Theater System Logo
142 people viewed this question
Top Coby Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
