Sony Ericsson XPERIA X1 Smartphone Logo
Question about Sony Ericsson XPERIA X1 Smartphone
Bluetooth pairing of Sony Xperia Z and Phillips HTL2160
During the Bluetooth pairing process, the sound bar is not visible although the Xperia is set as discoverable. How can I fix this
4 Related Answers
Anonymous
  • 7752 Answers
SOURCE: Bluetooth
scroll to settings/connectivity/bluetooth/turn off
if that does not work do a master reset...security default is 000000
Posted on Dec 21, 2007
Anonymous
SOURCE: Bluetooth file sharing problem
You can transfer only media files (don't know why). To do it, go to media, prees "menu", select "recieve using bluetooth" and after that send from sony ericsson.
Posted on May 29, 2009
Anonymous
  • 16 Answers
SOURCE: i have sony ericson xperia
Have you & him trusted both the devices first?
Sometimes this has to be done for the good smartphones that have secure wi-fi settings defaulty installed on the systems from manufacturers.
Go to your Connections settings.
Select: "Trusted Devices" if you have that one or similar wording.
Make sure your friends 9700 is selected as a Trusted Device so that you'd be able to pair information across.
Posted on Jan 01, 2011
Anonymous
  • 537 Answers
SOURCE: Sony Ericsson Xperia X8 Cannot
On the Home screen, drag the up arrow, find and click on your settings for wireless controls. Check the Bluetooth in the status bar settings. Find the Discoverable box and mark it. Your phone should be available for 120 seconds. Please make sure that your bluetooth is in pairing mode, flashing blue red. This should take care if the problem.
Good luck from Headsets Direct!
Posted on Sep 08, 2011
Unable to connect Sony Xperia Z1 to Altec Lansing T515 bluetooth portable speaker
1 does it have bluetooth
2 is it turned on
3 have u searched for devices i.e. in settings -- music -- play over bluetooth -- select device i.e. Portable Sound System Device / Click / Ok / Play?
Sony Ericsson Xperia X8 Cannot find Plantronics Explorer 230 Bluetooth Headset Why? Before was paired with Dell Streak and it worked perfectly.
2helpful
I am using xperia X10...and i want to connect to my HBH-GV435 bluetooth to this phone..but the HBH-GV435 blue tooth is already paired with some other phone.so i want to reset the bluetooth and connect it...
Headset-
1. Make sure the headset is fully charged, turned off and within 1 m (3 ft) of the phone.
2. Press and hold the On/Off button for at least five seconds, until you hear a long high-pitched beep and the light flashes red and green. The headset is now in pairing mode.
3. If your phone supports auto pairing, press "Yes" when the question Add device? appears in your phone. If it doesn't, continue with the next step.
4. Prepare your phone in accordance with the phone instructions for adding a Bluetooth device. Please note that for some phones you may need to enter a passcode. The headset passcode is 0000.
X10-
1. From the Home screen, tap the applications bar.
2. Tap Settings > Wireless controls > Bluetooth settings.
3. Mark the Bluetooth check box.
4. The phone starts to search for the device. Make sure that the device is in pairing mode. If needed, tap Scan for devices.
5. When the device becomes visible in the Bluetooth devices found list, tap to select it.
6. If needed, tap the text bar to enter the passcode (0000 by default) and tap OK.
7. You can now start using the paired Bluetooth device. The status of the pairing and connection is shown below the name of the Bluetooth device in the Bluetooth devices list.
Good Luck!
7helpful
How to send photos through bluetooth in sony xperia x8?
hi dineshblaste hit settings go to wireless&networks go to the bluetooth make sure it is check on. make sure the phone is in discoverable mode. Next hit scan for devices. One you find the device pair it with your phone. Next you should be able to send pictures via bluetooth. Also you can use media share on your device.You have several ways to send pictures. Ok hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
7helpful
2answers
How can i pass a song via bluetooth to another phone using my sony ericsson xperia x8?
1.select a song
2.go to option
3.there you can see the send option
4.select the sending option(bluetooth)
5.the bluetooth will search for available bluetooth connection
6.select the bluetooth connectivity which you have to send
How to active E500's bluetooth?
Hi tran_dat_syc.
After researching all the information online, I found the steps to enable the Bluetooth Device in the Computer.
Please follow the below steps to enable the Bluetooth Device in the Computer:
1) From the Today screen, tap the iPAQ Wireless icon located
in the Navigation bar at the bottom of the screen.
2) On the iPAQ Wireless screen, tap the Bluetooth icon.
3) When Bluetooth is turned on, the Bluetooth LED on the front of your Pocket PC flashes blue.
4) To turn off Bluetooth, tap the Bluetooth icon again. When
Bluetooth is turned off, the Bluetooth LED turns off and no
incoming or outgoing Bluetooth connections are possible.
5) Battery Saving Tip: Turn Bluetooth off when you are not using it.
For more information regarding to the Bluetooth Device, please refer to the User Guide mentioned below:
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00267893/c00267893.pdf
Please open the link above to view the User Guide.
Please refer to page 114 to 136 to view the detailed information to use the Bluetooth Device in the Computer.
Hope this helps.
Please feel free to ask for further questions.
1helpful
I have followed the directions given to me by the seller to pair my bluetooth to my Motorola Razr V3. Twice it has found it and said it is an H371. But that is all that happens. The process usually doesn't...
try these simple steps
1.first make your bluetooth on
2.there is anothr option of visible or something (make it visible for some time)
3.then on your bluetooth device.
4.It will ask you password
5.enter the password 0000 or (given password by retailer)
6.then your mobile will be paired with bluetooth device
2answers
Pairing bluetooth
First you have to check if the bluetooth is universal or works with your mobile phone; if it does then it could be that your phone has been set not to be visible to any device. You can change that by going to the bluetooth settings or option and change the visibility setting.
Nokia 6300 Data Transfer
Just check the visibility of your bluetooth, If it is hidden then you cannot pair other devices. You have to set the visibility as "show to all". It will be under bluetooth settings.
Top Sony Ericsson Computers & Internet Experts
Tom Chichester
ADMIN Andrew
ADMIN Andrew
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
