Question about Home
Why won't water turn off? - Home
Posted by Elaine Campbell on
  • Elaine Campbell
    Elaine Campbell Jul 06, 2015
    Installed a new stem in shower. When we turned the water back on there is water coming out of spicket and we cannot get it to stop.
  • Elaine Campbell
    We did that. After stem was installed, the water will not shut off
mike simpson
  • 712 Answers
YOU MUST SHUT OFF WATER FIRST!! Because you need to replace the valve stem washer. Most likely OO washer size, black hard rubber washer is worn out.
Remove the excursion (handle) one or hot and cold. Phillip screw or allen nut back of handle.
You will see a brass valve stem the handle was attached to. Use a crescent wrench and unscrew the stem and pull to remove.
Ar the bottom of the stem you will see the black washer. Remove the screw holding the washer in and replace with new. Reverse steps to install.
Hope this helps, I never know. Mike
Posted on Jul 06, 2015
My truck got hot yesterday cause of a blown heater hose and it won,t start today , i,ve got fire and i can smell fuel , but it won,t start
The first question I would ask, Is it turning over? If not, pull the plugs, and see if there is water in the cylinders. Water won't compress. Second question, if it is turning over, pull a couple of plugs and see if you find any water. Because you may have blown a head gasket. If you have, make sure you send the head to get it checked for cracks before reassembly. Good luck!! DD
Jun 01, 2014 | 1996 Chevrolet S-10 Pickup
Heater does not turn on
If you have a gas hot water heater that won't stay on, check to see if pilot light is out and relight it if it is. If you have an electric hot water heater that won't stay on, then you should have an electrician check the wiring.
if you need an auto tool you can click here: chinasinoy.com
Nov 05, 2012 | 1990 Toyota Corolla
Euro Pro X 1750 psi Pressure washer won't start. It's plugged in and water is attached. it was fine last time i used it.Now it makes a short noise like it wants to start, but doesn't.
Check the nozzle to see if is plugged. If water can" pass thru , it won't read a water pressure drop and turn on the pump motor.
Aug 26, 2011 | Garden
Pressure washer won't start. It has gas, oil and I turned the switch to turtle and to rabbit position. Does it matter if water is on first or not? It won't start either way.
Turn the water on, hold trigger down and let water run thru the hose to prime the air out of the hose. If it still will not start check the spark plug and clean it or replace it. A bad spark plug will keep it from starting
Aug 22, 2011 | Briggs Stratton 020273 Elite Series...
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Drove car thru water. Car died instantaly. water was knee deep. Pushed car out of water. will not turn over now.???
when you say it won`t turn over do you mean it tries to turn over with the starter or it won`t start.if you mean it won`t turn over then when it dries out a bit(water has drained from electrical components)try it again.if it still wont then its possible it may have sucked up water into the cylinder.pull the plugs and try to turn the motor over.if it does then this is the problem.if you mean it won`t start then let it dry still for water in a component may cause electrical issues when wet.just suggestions.
Apr 28, 2011 | 1997 Saturn SL
Stiebel Mini 4 won?t activate using 40l/min pump
You have to make sure that the pump is flowing enough water to activate the Stiebel. The tankless unit has a activation rate of a certain amount of water to turn it on.
Jan 18, 2009 | Stiebel Eltron Mini-4 Tankless Water...
Home Logo
119 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
