Question about DeLonghi Dehumidifiers
My Dehumidifier DEC180E is a couple months old; the fan works from time to time but the dehumidifier does not. What could be the problem?
I know the humidity is higher than the set humidity level because I measure it with a different hygrometer.
Posted by Walid Labaky on
5 Related Answers
Anonymous
SOURCE: Dehumidifier Error?
This error code indicates that the problem is most likely a shorted defrost thermistor or possibly a pinched wire going to the thermistor. You will need to replace the sensor assembly - part # 6877A30013L. The Sears website has it listed for 9.99 + shipping. The humidity sensor & defrost thermistor come together in a wiring harness that plugs onto the main circuit board. It is fairly simple to repair. Just remove the front & rear grill & the metal cabinet. Remove the thermistor from the copper tube on the cooling lines; remove the humidity sensor from the front of the evaporator; pull the wire plug off the bucket switch; & remove the small 7 pin plug from the main circuit board inside the metal control box. Reverse procedure to install new sensor assembly.
Posted on Nov 13, 2008
Anonymous
  • 3130 Answers
SOURCE: Dehumidifier Compressor is not working
this unit is very simular to an air conditioner except it has a humidistat instead of a thermistat.. if your handy with a continuity tester unplug the unit find the humidistat and check to see if its open or if its good then call the company at 1 800 322 3848 or contact the web site at [email protected] Good Luck
Posted on May 31, 2006
Richard Raynor
  • 225 Answers
SOURCE: Dehumidifier Does Not Collect Water
A dehumidifier is just a refrigerating machine with it's shirt hanging out and there is not much in the way of serviceable parts inside.
If the compressor runs - the throbbing sound - and it doesn't collect water then either the intake filter screen is totally clogged with fluff or the compressor has leaked it's gas away, in which case it might run continuously and get hot to no good effect.
If it doesn't run then it may be that the motor capacitor has failed, but that can soon lead to the compressor motor cooking itself; leaving you with an expensive doorstop.
The one thing you might get checked is the "bucket full" switch. There will be a floating part on the bucket which rises up when the bucket fills and eventually makes contact with another part which is connected to a small switch. If that switch has failed you might be lucky and get an inexpensive repair job done.
If these suggestions do help you solve the problem, please give my reply a suitable rating. If they do not, please add a comment with more details so I can try to help you further.
Cheers, D
Posted on Jul 01, 2008
Anonymous
Same problem with Goldstar model DH404EY7 -- stop code 01 on startup, bucket full light blinks (drains to floor).
Replaced the main controller board to fix it.
For my model dehumidifer the part # is 6871A20888A, and cost $77.44 (not counting shipping) from Appliance Factory Parts. The Appliance Factory Parts web site also provides parts breakdown (exploded parts diagram) diagrams and service manuals in PDF form.
Posted on May 02, 2009
robotott
  • 21 Answers
SOURCE: water is not condensing
Most dehumidifiers do not have an air filter and periodic coil cleaning is required. Remove the plastic housing and clean coils with water or air. Be sure unit is unplugged and dry before plugging back into the wall soket.
Posted on Jun 27, 2009
My dehumidifier is (6) years old. Only used (4) months a year in this climate. Plugged it in this year for the first time and the fan is blowing on high without the power button on. Fan speed control with...
My guess is something got into the controls and has shorted the power to the fan. Take panels off of the unit and vacuum, and wipe or brush, with soft brush, as much as you can. Do not use any liquids in cleaning. Hope this works for you.
Jun 01, 2011 | Maytag M7DH65B2A Dehumidifier
My Haier dehumidifer runs but doesn't collect any water. I have another exact same dehumidifier sitting 10 feet away and it fills up about every 24 to 36 hours so I know the conditions are that it...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 12, 2011 | Haier Dehumidifiers
My dehumidifier (new air AD 400, 6 months old) stopped working. Fan blows, humidity level is indicated, motor gets hot, but no water comes out. I tried unplugging, resetting, etc to no avail.
heatman101
Sep 18, 2010 | NewAir AD400 Dehumidifier
My delonghi dec180e dehumidifier filter is jammed in the machine. it's also now leaking - how can I fix?
you can download the manual here: www.delonghi.co.uk/pdf_files/DEC180E.pdf
thanks
Paddy
Feb 02, 2010 | DeLonghi Dehumidifiers
Fan runs, but compressor does not start
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jul 05, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
Dehumidifier
if it does not get cold anymore, then a freon charge is necessary, provided the compressor was not damaged from "left it on for a long time once and found that ice had developed on it. I know that being left on could cause a problem"
Jun 03, 2007 | Fedders A7DH65B2A Dehumidifier
Dehumidifiers Logo
105 people viewed this question
Top DeLonghi Dehumidifiers Experts
jdthefixer
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
