Question about Danby DDW1899WP Portable Dishwasher
How do I repair a shorted white wire connecting the plug to the machine?
The plastic part that connects the plug to the machine has melted. What part(s) should I purchase to repair? Is this conceivably DIY or should I call a repair service?
Posted by Serafina C on
Repeated melting of wiring harness of brown/white wire connection. replaced/spliced into new pigtail. Now blowing 15 amp fuse to instrument cluster,tail lights. Any ideas?
If the wire and connection keeps burning /. melting, it would suggest that whatever that wire is supplying power to is overloading the circuit. Trace the wire to see what it is powering and check if the component has shorted / jamming. Normally however, if something is shorting or overloading the circuit, you would expect the fuse protecting that circuit to keep blowing.
Sep 17, 2015 | 1992 Mercury Grand Marquis
AC Input Line Produces Smoke
yes you can re-strip the wires and replace the conenctor nut. the melted wire were the reason of loosely connected wires that increases the temp od the wires and melt it.
Jul 07, 2008 | Maytag MDBH945AWW / MDBH945AWQ /...
I have a JS968 GE Profile range that the ASM sensor went bad. When pulling the sensor to replace it with the new I discovered that the plastic connectors had disintegrated from heat. Is it possible to...
Hi. Yes it is possible to connect the wires with wire nuts. (Without tape! / tape can melt) You must use ceramic / porcelain wire nuts (white) in HOT areas. Make sure it is a clean connection with no copper strands exposed The plastic ones will melt like your connector did. Most appliance parts supply stores will have ceramic / porcelain wire nuts.
Here is a source for ceramic wire nuts if you can not find them. (15 ea / pack) $5.65 +shipping
http://www.repairclinic.com/PartDetail/Porcelain-Wire-Nuts/241068
Thanks for choosing FixYa,
Kelly
Nov 08, 2010 | GE Kitchen Ranges
Electrical Short in Printed Circuit Board.
Hi, do you know what these wires were for? You can bypass the board, but if the wires are for lets say the blower motor and you bypass and put them to direct hot legs, you will run all the time, or what ever shorted the block in the first place must have a short. Its probably in the wires at this block and if you apply it to 120 volts it may fry again. I would follow these wires back to see what they run first. Yes, it can be done.
Shastalaker7
Jun 08, 2010 | Amcor PLM-14000E Portable Air Conditioner
I need to replace my headphone plug end
See my tip on replacing dodgy cable and plugs on headphones.
May 26, 2010 | Sony MDR-V150 Professional Headphones
One of the connections is shorting and melting the plastic the plastic on the wire is also bubbling, how do we fix this as the lights are also not coming on from that connection.
The connectors get loose and corrode over time, resulting in a high resistance connection that produces a lot of heat, melting the connections, as you have witnessed. Cut back the wires to good insulation and splice them with waterproof splice connectors or waterproof wire nuts from the local hardware.
You'll need two connectors or wire nuts. Each connector will connect 3 wires: one wire IN from upstream , one wire OUT to the next light, and one wire to the light.
Since the voltage is 12 volts AC, polarity doesn't matter, however, if you look closely at the cable, you'll see that one of the wires has ridges.
Now is also a good time to check the connectors on the other lights.
May 19, 2010 | Malibu ML300RTW - Low Voltage Power Pack...
Short circuit w/ fire and stinky smoke
no you need to rewire all again but take it out of the power first.
Dec 31, 2009 | Kenmore 53542 / 53544 Side by Side...
Wiring on top of battery case looks to be melting
The wire that is getting so hot may have gotten chaffed and shorted out. do you have aftermarket accessories connected ? They may be drawing too much amperage.
Feb 17, 2009 | 2003 Volkswagen New Beetle Convertible
WIRING DIAGRAM? FOR BLACK AND DECKER ELECTRIC LAWN MOWER
the pic says the connection are not right.all left side connection are for brake which is the red & white wire. all right side connection are two black wire.
Feb 06, 2008 | Black & Decker 19" Electric Lawnhog...
Replacement power cord
Fryers draw high amps.Goto home depot,lowes and buy a 15amp 125 volt plug.Cut the exsisting plug off the cord,strip the cord down 2 inches you will see 3 wires black,white,green, connect the green wire to the green screw on the plug.connect the other 2 wires on either of the remaining spades(it doesnt matter).let me know
Nov 22, 2007 | Bravetti EP4305FS Deep Fryer
Danby DDW1899WP Portable Dishwasher Logo
89 people viewed this question
Top Danby Dishwashers Experts
Michael Thomas
Michael Thomas
Andrew Taylor
Andrew Taylor
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
