SOURCE: where can I get a power cord for niko 26 inch?
95% of all LCD's use the standard PC or Monitor cord. Best Buy ect...
SOURCE: What do I clean the 26 inch Insignia HD Flat
Take a cloth and there are many solvents available in the market bring it and take a tissue and wipe the Flat screen Tv its simple
SOURCE: Insignia 26 inch Flat Panel Internal Speakers Stop working
You need to test the unit on a external sound source, to see if the audio amplifier is working correctly. By checking it on another source you can determine if the sound amplifier system is failing or you have had some problem with you speakers. Once you determine the problem. If it is the speakers, you can replace them with new ones. However if it is the audio amplifier section failing you will have to take it to a service center where they have all the service information to do the repairs.If the unit is still under warranty, have it serviced by Insignia. You can reach their customer support with this telephone number !-877-467-4289. Give them the model number of your television and the problems you are having with it. The should be able to tell you how to have it serviced. You can also check out their website for customer support at www.insignia-products.com. If the unit is out of warranty, you must have someone help, you troubleshoot the problem and try buying parts for the repair. You can call this number for insignia parts. 1-888-237-8289. You can also search the Best Buy website for parts on these units. The website is www.bestbuy.com. Go to the parts search section and put in the brand name of you television and put in the model number. The search engine will bring up a parts list with prices. I hope this information has helped you with your problem. You should also be aware that Best Buy has had a recall of some these model units. Check my tips and hints postings for more information.
SOURCE: No Picture-white screen
Ur Tuner board,that the tv signal came into that board.U have a little manchanical skill.Take ur tv aparts.Replaced that Tuner board ur tv will work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board to replacement.
