Question about Vizio E601I-A3 60-inch Class Razor LED HDTV - Smart TV - 1920 x 1080 -
My tv has a crack in the scream i want to know can it be fixed
Posted by Patricia Peagler on
De ice
    Diehard:
    Visited the website for 60 consecutive days.
  • Vizio Master
  • 711 Answers
My cracked the corner of the tv and the tv turns on fine I want to know if it can be fix and it's worth fixing
If it works, you just need a used caseing, or just leave good enough alone. Peace
I DJ karaoke and someone screamed really loudly into my mic. Now my speakers cut out if anyone sings too loudly and the sound, in general, is crackly. What part of the speaker is most likely damaged?
The voice coil(s) of the speakers (replace the individual failed speakers as you can't replace the voice coil separately) or the amplifier's output transistors / vacuum tubes - or - both. That was a loud and potentially expensive scream.
My vacuum sounds like it is screaming the entire time it is on. We have cleaned out every possible area, but it is still extremely load. Any suggestions?
Is it cleaning as good as it used to? 1) If not there may be an air leak.
A crack or a hole will allow air to rush in. The motor will make a louder noise when not under load. 2) Have you changed house locations, ie Country? Diffferent house voltage will cause this screaming.
Model number- IWT3206 A, when i plug it into an outlet the curcut board screams and wont turn on what can i do to fix it it has to be simple
The circuit board has burnt out. At this point you will have to use a universal remote or some type of cable remote to operate your TV.
37" full hd philips tv screen cracked because
If there is picture in the TV then probably it is the protective screen that has cracked and not the picture tube.Please check carefully.
My screen cracked on the inside wanted to know if it can fix. model LT-42X579 THANKS
No fixing a cracked screen, and replacement is not worth it, you can check places like vancebaldwin.com
2answers
When starting up the Kia, screaming belts sound is heard
I'm not sure if its the same thing but when this 'screaming' happend to my Sportage it was the CV joints and a $400 fix. nothing to do with the engine or belts.
Open Questions:
See all Vizio E601I-A3 60-inch Class Razor LED HDTV - Questions
Vizio E601I-A3 60-inch Class Razor LED HDTV - Smart TV - 1920 x 1080 - Logo
Top Vizio Televison & Video Experts
Ekse
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
