Question about Whirlpool Duet GHW9150P Front Load Washer
How-To Unlock The Controls For A Whirlpool Duet washer
Posted by Robert Luyster on
Don Meixner
    New Friend:
It was worth a try, but did not work for us.
Posted on Aug 10, 2016
Amrit sahni
    Guru:
  • 283 Answers
  1. To unlock the controls: Press and hold the End Of Cycle Signal button until the Control Lock light goes Off. To lock the controls: Press and hold the End Of Cycle Signal button until the Control Lock light comes On.
Posted on Aug 24, 2015
prem mathew
  • Whirlpool Master
  • 662 Answers
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds. The lock light goes off.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
Posted on Jul 04, 2015
Andrea Szabo
    New Friend:
  • 4 Answers
I have unplugged the machine and plugged it back in and restarted, just like when a computer needs to be reset/cold boot.
  • Anonymous Jul 14, 2015
    The control can be unlocked by pressing and holding the End of Cycle button for 3 seconds, or until the Control Locked indicator turns off. Unplug the machine for at least 30 minutes to forcibly reset the control to make sure and eliminate the possibility of an electronic glitch; if the End of Cycle button does not unlock it. Replace the control if unplugging and the End of Cycle button fails to unlock it.
The control lock is on and washer control light will not light up nor will the washer start.
To unlock the controls push and hold the END OF CYCLE SIGNAL button for 3 seconds to unlock the controls
GENE
Oct 31, 2011 | Whirlpool Duet GHW9150P Front Load Washer
THE DISPLAY WINDOW SAYS CONTROL LOCK. WHAT DOES THIS MEAN?
Press and hold the End of cycle button for 3 seconds or until the Control Locked indicator turns off. Click on the link below for more details if pressing and holding the said button doesn't unlock the controls.
Unlocking the Controls on Whirlpool Duet Washers
Jun 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool Duet washer - the controls are "locked". How do you unlock the controls
Hi, Try pressing pause/cancel twice and drain the machine of water then check the filter for any blockages, when done try and run a program.
I'm assuming the display is on and you cannot enter a program.
hope this helps.
Feb 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Trying to get the controls unlocked does anyone know how my 16 month old grandson can lock it and i cant unlock it
Hello
Your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE button for 15 seconds to unlock the control. Please get back to me if you have any other questions.
Kevin
Dec 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: The control lock light is lit on my whirlpool duet...
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control is locked
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED Status light turns off.
Feb 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Unlock controls whirlpool direct washer
Feb 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
WHAT IS 'CONTROL LOCK' ON THE WHIRLPOOL DUET
Control Lock is a designed safety feature that allows you to lock/unlock the control panel to prevent small children from manipulating the controls. To lock or unlock the control panel, click on the following link:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
If this does not fix your problem, please let me know. I hope this helps you.
Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool help
Press and hold the "End of Cycle Signal" button down for 3 seconds and the control lock should clear. Hope this answers your question.
May 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
795 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
