Question about Elna Sewing Machines
How to remove a can from a elna Carina electronic 65
Posted by maria medina on
Tally Girl
  • Elna Master
  • 1,134 Answers
You need to set the stitch width dial to zero, the stitch length dial to zero so that the cam following arm is disengaged and moved back off the cam. Now look at the cam, it is sitting on a silver shiny spindle, press down onto this with your fingers and this will unlock the little finger which locks onto the cam, releasing the cam upwards. Press firmly and it should release.
Posted on Jul 19, 2015
5 Related Answers
Tally Girl
Tally Girl
  • 1134 Answers
SOURCE: my Elna Carina 65 doesn't feed fabric . I've
Is it possible that you've lowered the feed dogs and not raised them again? Is the stitch length dial set to 2.5 and not on a buttonhole blue setting or the Automatic "A" setting?
Posted on Mar 27, 2011
Tally Girl
Tally Girl
  • 1134 Answers
SOURCE: I need an instruction manual for the Elna Carina
There is a sewing guide available free here for the SU which is very similar to the Carina
http://www.arizonaexpressionz.com/elna_instruction_manuals/SU_air_electronic.pdf
but not an instruction Manual.
The SU, Carina, 500 and Jubilee all came with two books, instruction manual and sewing guide.
Posted on Jun 16, 2011
Tally Girl
Tally Girl
  • 1134 Answers
SOURCE: Hi, I have an Elna Carina and the flywheel is
I can direct you to a service manual for your machine but it may be something that you need a trained Elna service technician to deal with.
Link is http://www.arizonaexpressionz.com/elna_service/air_elec_carina_elec_SM.pdf
I am more familiar with the SU air electronic where you just hold the outside of the flywheel and turn the inside knob to disengage and rengage the clutch - didn't realise the Carina had a button flywheel release until I looked in the service manual.
Anyway, you could try dismantling the flywheel following the exploded diagram in the service manual if you are technically minded.
Or just take it to a reputable serviceman, I'm a big fan to supporting these guys as their knowledge is invaluable.
Posted on Jul 13, 2011
Tally Girl
Tally Girl
  • 1134 Answers
SOURCE: Elna Carine Electronic Sewing Machine
You should be able to buy a manual online but it may be a cd or image pdf file. Try www.sewingpartsonline.com or www.sewusa.com. If they don't have the Carina but have the Air Electronic SU, model 68 then this will be almost the same. Main difference is the Carina has the needle up/down button.
Here is threading up images to get you started.
Posted on Sep 28, 2011
SOURCE: elna carina 390 b power cord/foot pedal
check with a elna dealer
sew4less.com
sewingmachineplus.com
ebay
Posted on May 29, 2012
ELNA CARINA FOOD PEDAL NOT WORKING
Elna Carina has an air electronic foot controller, so you need to firstly check the air line coming from the round air pedal has no holes, is not crimped or squashed under the chair leg. Hold the plug end against your hand or cheek, squeeze the round bulb and see if you can feel a puff of air coming from it. If no, then check the air control black membrane for a hole, ditto the air line hose. You can still buy parts from sewingpartsonline.com for these Elna Carina Electronic 66 Parts . If the line and foot pedal are sound, then the problem lies on the internal actuator which is inside the right side panel of the machine. You can remove this panel by undoing two screws on the side (disconnect from power first!)
The panel will remain connected to the machine body by some cables, you may be able to check out the actuator and see if it is faulty. If its just a tiny hole in it, it might be repairable with a drop of superglue. For parts/service in the USA, Whites Sewing Center is the Swiss Elna specialist, and they may have spare parts in stock.
Feb 09, 2015 | Elna Sewing Machines
I used a single cam in my Elna Carina and I can't remove it. help!
ELNA Carina Instruction Manual
Perhaps the spindle where the cam sets needs a drop of good quality sewing machine oil, like Tri-Flow Synthetic Lube. Be sure the stitch length & width are set to Zero.
Elna Carina Electronic SU Duplex Review
How to remove can from an elna Carina Its stuck and can remove it My...
Dec 19, 2017 | Elna 2007 Mechanical Sewing Machine
Elna carina snap on presser feet
Yes, any low shank should work. If it doesn't you can always regift it to someone.
Oct 27, 2017 | Sewing Machines
I have an Elna Carina model # 22620738-412 Type 65 machine w/o a power cord. Do you have one and how much is it?
What voltage, are you in USA? If yes suggest you browse www.whitesewingcenter.com for Swiss Elna parts.
Apr 14, 2011 | Euro-Pro 473
I need an instruction manual for the Elna Carina Electronic sewing maching
Oct 25, 2010 | Elna Sewing Machines
My Elna Carina 65 doesn't feed fabric . I've
Feb 23, 2009 | Elna 8007
Sep 21, 2008 | Elna 8007
Sewing Machines Logo
119 people viewed this question
Top Elna Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Nick Olsen
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
