Motorola MR350R  Two Way Radio Logo
A
Anonymous Posted on Jul 02, 2015
Is there a way to reset it to factory settings? Midland has it...
  • Official Brand Answer 3,100 Answers
  • Posted on Jul 03, 2015
Motorola Mobility
Level 0:
Answers
3100
Questions
Helped
684971
Points
13487
Midland Allan 78 plus multi, stuck on Italian channels,I have even tried a factory reset with no results.
I'm assuming that you mean that it's on Italian language not channels. The best way to try and figure it out, is to get an Italian to English dictionary and look up the translations.
One of my midland GXT635 won't send or receive from my other one.
Yikes- Sounds like it's time for factory servicing! Hopefully, they still support that model. If not you'll probably have to buy a new one.
How do you reset the Midland 2 way radios
Try removing the batteries to reset the defaults.
2answers
How to delete a county in my midland WR120
The way I did it was to unplug the power supply and remove the batteries for a minute, this cleared all the settings. Put it all back together and then reset station.
My Midland walkie talkie quits transmitting about 3 seconds after I start transmitting
It is more likely a power issue. PTT switches do not normally cause a short circuit. Check the batteries, swap the batteries and see if that helps. Radios take a great deal more power to transmit than turn on or receive. If not the battery, try a low voltage battery, such as a cordless phone battery. If it still occurs, check your warrany and send it back to the factory.
MIdland WR-300/301 Was told by Midland that the reason I can longer get weather reports/alerts is because the crysrtal for weather reporting is bad. Radio Shack person said he needed schematic to find out...
Midland WR 301 Owner Manual
I just finished reading through the owner manual and it didn't say anything about a crystal anywhere. Possibly the setting is incorrect for receiving the weather reports/alerts. Click on the link above and verify you have your setting for weather reports proper.
Semper Fi,
Z
4helpful
2answers
Weather radio just gives off high pitch squeal and no weather info.
If you hold the WEATHER/SNOOZE button and the VOLUME UP button, it resets the radio to its deafult factory settings.
How do you do a factory reset on the wr-300?
Got some very un smart people on here that don't know a car from a radio! LOL LMAO.....DAH....
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
