Question about Canon New Compatible Black Print Laser Ink Toner Cartridge Cannon 104 Better Than Aftermarket Refurbished Recycled Or Refilled Replacement For Imageclass/image Class Mf4110/mf-4110 Mf4120/mf-4120 Mf4122/mf-4122 Mf4140/mf-4140 Mf4150/mf-4150 Mf4270/mf-4270
What is the fault, my printer is not print/copy continuous, only first page print then all blank, for another print/copy printer require switch off & on,again face same problem
Posted by sanjay68 on
ray gallant
    Top Expert:
  • Canon Master
  • 68,344 Answers
Have you tried uninstalling and re installing software ,sometimes that works
Posted on Jul 02, 2015
Printer only prints top and bottom lines on page
All web based documents, especially bank statements, require a COLOUR cartridge, so if your cartridge is empty, it will print blank pages. Although the font may look black... it is normally NOT. Altentaively you may also need to instruct your printer to print "background images".
Jul 08, 2012 | HP Deskjet D1000 J110a Printer Catalog...
HP CM2320 MFP blank pages come out with printout
Hi my hp cm2320 nf prints normally and prints when you press the color copy button. But it will printout only blank page swhen you copy black&white. You press the black&white copy button only blank pages come out. Any help
Lang Dibba, Gambia
Jan 30, 2012 | HP Laserjet CM2320nf All-In-One Color...
My HP M2727nfs prints blank pages. Even demo page / reports are blank. NO errors on display. Paper gets warm, so fuser works. New cartridge doesn't help. Neither cold reset. What can this be?
This is a problem with either the formatter board or the dc controller, try doing an nv ram ( turn off the printer and hold down the right arrow and the cancel button, turn the printer back on and continue holding until you see permanent storage init). If this doesn't work call hp tech support 1800 334 5144 and ask for a case number. This printer has a service note which will cover the formatter for 2 years.
Al
Sep 14, 2010 | HP Laserjet M2727nf Multifunction Printer
My hp officejet 6210 all in one is instaled under general heading: officejet 6200 series. Result: the printer reacts to command given by laptop windows xp but does not print given text. The paper comes out...
Are you able to print Self test page from printer ( standalone ) or able to make a copy ? if you are able to make copy/print self test page from printer, this issue is with Printer Drivers, You can uninstall and reinstall the software ( download the latest software and drivers from HP website )
If you are not able to make copy/print self test page from printer, it is issue with printer/cartridges... you need to re-align the printer
to clean/align cartridge
On Printer Front panel
Press - Setup Button ( press ok)
Press - Tools ( Press Ok )
Press - Clean Cartridges ( Press OK )
And/Or
Press - Align Cartridges ( Press OK )
Jun 22, 2010 | Office Equipment & Supplies
I cannot get my MFC-440CN to print. I try to copy a page and it sounds like it is copying but all I get is a blank page. I try to print out an email and get a blank page. I have cleaned the print...
Give You advice, make sure that there is ink in inkwell. Then **** to wipe sniffled the inkwells, ****. Afterwards **** safely to insert little press on inkwell. Try insert other inkwell. Unless prints the code to faults, signifies the head of the inkwell ???????. Soak off in ammonia with water on night. Uninstall and reinstall driver, give the following recommendations:http://wiki.archlinux.org/index.php/Brother_MFC-440CN
Sep 21, 2009 | Brother Office Equipment & Supplies
Printing blank pages
open the door and look for a unit that has some small hair like wires, are they intact or is one missing /broken???
Oct 30, 2008 | Canon imageCLASS MF6550 Monochrome Laser...
Leaking black ink on printed pages
Hi, please attempt to run a numerous blank paper through the printer. This will dry or clean any ink found on the rollers.
Continue to run blank pages through the printer until no more ink is found on the paper, then attempt printing. If ink stains or streaks are still present, the printer may need service.
Tirzo
Jun 12, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Canon New Compatible Black Print Laser Ink Toner Cartridge Cannon 104 Better Than Aftermarket Refurbished Recycled Or Refilled Replacement For Imageclass/image Class Mf4110/mf-4110 Mf4120/mf-4120 Mf4122/mf-4122 Mf4140/mf-4140 Mf4150/mf-4150 Mf4270/mf-4270  Logo
317 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
