Question about Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
My tv has a display delay
The last 6 to 8 inches of the display image lags behind then gradually fades what needs to be done to fix this?
Posted by evelyn on
    Top Expert:
  • Sony Master
  • 76,455 Answers
T'Con board fault. Contact any service technician. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Jul 02, 2015
How do I fix a thin black horizontal line on my LCD TV?
T'Con board fault.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 11, 2014 | LG 42LS5600 106.7 cm 42" 1080p LED-LCD TV...
I HAVE BOUGHT AN RXV367 A FEW WEEKS AGO. IT IS SET UP WITH A VIRGIN HD+ BOX, BLU-RAY & TV. THE PROBLEM I HAVE IS THAT WHEN WATCHING PEOPLE SPEAKING, THEIR VOICES ARE NOT IN SYNC WHEN CONNECTED.IF I...
It's the nature of the beast. The TV has to process the digital video bitstream more than the receiver has to process the audio so the result can be a gradual lagging of the video behind the sound...
http://en.wikipedia.org/wiki/Lip_sync
Some receivers have a sound delay control which you can use to try to sync them up. You didn
Mar 12, 2011 | Yamaha RXV367 Receiver
I have a series 6 samsung tv connected to virgin digital hd box by hdmi cable also samsung blue ray by hdmi cable if i watch a blue ray or something on virgin hd the sound is usually out of sync with my...
Mar 12, 2011 | Audio Players & Recorders
The video on my hd tv is delayed and the audio on my sround sound is not i have philips blueray home theator how do i fix this problem.
Mar 05, 2011 | Philips Audio Players & Recorders
I have a sony dav-s550 and the sound and picture are not in sync. Looked in the manual but it doesnt say anything about it.
Some receivers have a sound delay control which you can use to try to sync them up. You didn't name yours so one does not know. Look in the manual. If it's not there then there is no audio delay to eliminate it.
Mar 04, 2011 | Sony DAV-S500 System
I have my Onkyo tx ds656 hooked up to my HDTV via the cable box. Everything works fine, except that there is a noticible delay in the syncronozation of the sound and the video. Is there any way to correct...
Some receivers have a sound delay control which you can use to try to sync them up. I didn
Jan 24, 2011 | Onkyo TX-DS656 Receiver
I must often turn home theater system off and back on to get sound synched up with picture. Mouth not moving in snych with dialogue. Please advise. bob
Jan 18, 2011 | Audio Players & Recorders
Lag problem - Guitar Hero / Wii / Philips 32PF5321/10 tv
Usually the video lags behind the audio. The reason is the video, in many TVs, takes longer to process than the audio coming direct from the device. To solve this, the audio needs to be delayed. This can be done by 1. Using the tv audio output. Most TVs sync the audio to the picture and this 'synced' audio is available at the output jack of the tv. 2. Delay the audio coming out of the device. Many home receivers have a 'Lipsync' feature designed for this issue. The setting is usually between 50 to 500 milliseconds of delay, depending on the TVs video processing time.
I hope this is clear and can help.
Mar 04, 2017 | Philips Televison & Video
Time lag between Playstation 3 and LCD TV.
SOURCE: http://boardsus.playstation.com/playstation/board/message?board.id=confrontation&thread.id=735278&view=by_date_ascending&page=2
If your playing with lag on your new HD LCD your at a competitive disadvantage! Everything you see happens seconds later than your opponent who has his/her settings right.
The fix:
1. Connect your PS3 using HDMI Input 2.
2. SELECT or RENAME the HDMI Input to PC. Already pointed out, but this does not make the majority of tv's run in PC mode.
3. On the PS3 start-up menu go to Settings---> Display ---->
Choose HDMI ----> DO NOT choose AUTOMATIC ----> SELECT CUSTOM ----->
4. Now, Select all the Resolution options EXCEPT 720p. This will force your games into 1080p mode. What it will also do is drop any game that doesn't have 1080i/p support into 480. Games like Burnout Paradise, Vegas 2, Heavenly Sword, NHL 08 and more will be dropped into SD (480) rather than HD. Your picture will be terrible. 720p is standard gaming resolution currently, 1080i/p is not.
5. Save and complete the display setup.
6. Turn off the PS3. Turn off the TV.
7. Turn on the TV. Turn on the PS3.
8. Complete! (Lag eliminated). Please spread this around!
*The key to eliminating ALL LAG is modern LCD's need to be in PC MODE (NOT GAME MODE) On many tv's, PC mode requires you to use a VGA or DVI connector. You'll either need to buy an HDMI adapter or an HDMI to VGA / DVI cable if that's the case.
and the Source MUST BE IN 1080p so that the TV can use it's NATIVE RESOLUTION.* Please, check your tv's native resolution. If you have a plasma that only does 720p, your native resolution is probably 720p. You do not need to follow these steps, it will only make things worse. If your tv's native resolution is 720p, obviously you want to keep your display settings at 720p on your PS3. If your native resolution is 1080i, you shouldn't go selecting 1080p. If your native resolution is 1080p on your TV, you need to be aware that removing 720p as an option will force many games into 480.
Keep these things in mind and remember that the steps above are far from a cure all solution. .
Lag gone! Worked for me! (SAMSUNG LNA52850)
Source : http://answers.yahoo.com/question/index?qid=20081225141902AApX7cJ
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Sony BRAVIA KDL-52W4100 52 in. LCD HDTV Logo
76 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
