SOURCE: upgrade vista home premium
As per my knowledge, there is no version of Vista called Vista Professional like in Windows XP.
Make sure what is the version to which you want to upgrade to from Vista Home Premium to Vista Business or Vista Ultimate.
The available versions of Vista Operating Systems along with the features supported from the Link below :
http://www.microsoft.com/windows/windows-vista/compare-editions/default.aspx
However, if you want to Upgrade the current version of Vista to a higher version like Vista Business or Vista Ultimate, you need to purchase Vista Anytime Upgrade kit from any retail store or directly from Microsoft.
You can find the required information related to Anytime Upgrade Kit from the link below :
http://www.microsoft.com/windows/windows-vista/get/anytime-upgrade-overview.aspx
However, make sure that you had created the Recovery Disks for your notebook using which you will be able to reinstall the preinstalled Operating Sytem along with all the Preinstalled Applications and Drivers after which you need to use the Vista Upgrade Kit to upgrade to higher version of Vista.
However, if you are currently having a 32 Bit Vista preinstalled in the Notebook, it is not possible to upgrade to a 64 Bit Vista since you can upgrade only a 32 Bit of Operating System to a higher version of 32 Bit Operating System and a 64 Bit Operating System to a higher version of 64 Bit Operating System.
Hope this helps....
SOURCE: Need password unlock code for HP Pavilion dv5
You can start it in safe mode pressing the F8 key...it change between brands but must out there use f8... when you start in "safe mode" in the log in screen you will find your user name and the administrator one...normally the administrator don't have password, so you can log into it and there you have the permission to delete other users passwords...
If you don't found that option, there is an other option but you need to download it and burn it in a cd... Is called ERD Commander here is the link for it: http://rapidshare.com/files/113560492/ERD.Commander.2008.CrOwN.rar... the password for decompress it is:( munda
) when you have burned it, insert it in you cd drive> go to your computer bios>select boot priority>change it for boot from cd first...once you have done that press f10 and select the option yes to save your settings and restart your pc....then your computer will start with a wizard looking like windows xp...complete all the things that it request...when finally boots up>go to start menua and select system tools>locksmith and delete all the passwords that you want...that's it! restart without the cd in the drive and log in! "Hope it works for you"
SOURCE: HP Pavilion dv7-1240us does not restart
Press and hold the power key. It should shut down (or just pull the power).
Restart the PC and do not press the escape key
SOURCE: NTLDR IS MISSING for HP 530
copy e:\i386\ntldr c:\
copy e:\i386\ntdetect.com c:\
Once both of these files have been successfully copied, remove the CD from the computer and reboot.
SOURCE: the screen will not power up on my hp pavilion dv7 4065dx
it is the motherboard it is fried and u will have to pay 400 plus bucks to get it repaired. happened to me too. not worth it. just buy a new one
