Question about La Crosse LaCrosse Atomic Digital Wall Clock with Wireless Temperature Sensor
CANNOT SET CORRECT TIME ZONE, WANT MOUNTAIN ZONE, STAYS ON LAX DST.
How to set time
Plug in the unit.
First, the month and date appear, then the
year, and then the current Eastern Standard/
Daylight Time appears in the display.
Press
TIME ZONE
Area number "2" appears in the display.
If you live in the Eastern Time zone, you do
not need to adjust the area setting.
Area number
Time zone
Atlantic Standard/
Daylight Time
(default)
Eastern Standard/
Daylight Time
Central Standard/
Daylight Time
Mountain Standard/
Daylight Time
5
Pacific Standard/Daylight
Time
6
Yukon Standard/Daylight
Time
7
Hawaiian Standard/
Daylight Time
Press
TIME ZONE
repeatedly until the
desired number appears.
The display returns to the clock about 4
seconds after the operation is complete.
Note
During the shipment and your first use, a clock
error may occur. In this case, refer to "Setting the
clock and date" to set the correct time.
When daylight saving time
(summer time) begins
This unit employs Automatic Daylight Saving
Time/Summer Time adjustment. The DST
indicator appears in the display at the beginning
of the daylight saving time (summer time), and
disappears at the end of it.
Daylight saving time begins at: 2:00 AM on the
second Sunday of March.
Standard time begins at: 2:00 AM on the first
Sunday of November.
To cancel the automatic DST/summer
time adjustment and to set DST display
manually
The automatic DST/summer time adjustment can
be cancelled.
Press and hold
DST
for at least 3 seconds while
the clock is displayed.
A beep sounds, and "Aut
OFF" appears in the
display to show that the automatic DST/summer
time adjustment is cancelled. The display returns
to the clock.
Notes
Daylight Saving Time depends on the law in
each country/region, and your area may not use
it. In such a case, cancel the automatic DST/
summer time adjustment before using the set
and set the time manually as necessary.
To activate the automatic DST/summer time
adjustment again, press and hold
DST
for at
least 3 seconds. A beep sounds, and "Aut
On" appears in the display to show that the
automatic DST/summer time adjustment is
activated. The display returns to the clock.
To change the display to the daylight saving
time (summer time) manually, see "To change
the display to the daylight saving time (summer
time) indication."
Setting the clock and
date
To change the setting manually, follow the
procedure from step
Press
CLOCK
for at least 2 seconds.
You will hear a beep and the year will start to
flash in the display.
Press
or
until the correct year
Press
CLOCK
Repeat steps
and
to set the month,
day and time.
After setting the time, two short beeps sound
and the clock starts from 0 seconds.
Pressing and holding
or
changes the year,
month or day rapidly.
When setting the current time, time changes
rapidly by 1 minute-increments up to 10
minutes, and then by 10 minute-increments.
While setting the clock, you must perform each
step within 65 seconds, or the clock setting
mode will be cancelled.
To display the year and date
Press
SNOOZE/DATE/SLEEP OFF
once for the
date, and within about 3 seconds press it again for
the year.
The display shows the date or year for about 3
seconds and then changes back to the current
time.
If you connect the AC plug to an AC outlet while
this unit is powered from the backup power
source, the current date and time appears in the
following order (the same as when the unit is
powered on after a power interruption).
"month and date" (about 1 second)
"year"
(about 1 second)
"current time"
saving time (summer time) indication
Change the daylight saving time (summer time)
adjustment setting according to the following
procedures if you have cancelled the automatic
DST/summer time adjustment.
Press
DST
The DST indicator appears in the display and the
time indication changes to the daylight saving
time (summer time).
To deactivate the daylight saving time (summer
time) adjustment, press
DST
again.
May 24, 2015 | Sony SY-ICF-C414 Clock Radio
How do I set the time zone? It run out of battery so when I changed it, the time zone is pacific and I need to change it to mountain time.
To change the time zone, open the control compartment cover on the bottom of the clock. Locate the "Time Zone" switch and set it to the appropriate time zone for your area. Six time zones are programmed into your clock, "A" for Atlantic, "E" for Eastern, "C" for Central, "M" for Mountain, "P" for Pacific and "H" for Hawaiian. Once you've chosen the correct time zone for your Brookstone digital desk clock, you must select whether you want the clock to operate using the 12-hour or 24-hour format. The clock is set to the 12-hour format by default. If you'd like to change the setting to the 24-hour format, locate the "Time Format" switch on the bottom of the clock and flip it to "24-hour".
You can also decide whether to turn your clock's automatic Daylight Savings Time feature on or off. If you turn the feature on, your clock will automatically move forward by one hour at 2:00 a.m. on the first Sunday in March and fall back by one hour at 2:00 a.m. on the first Sunday in November. To choose your preference, locate the "DST" switch on the bottom of the clock and flip it to "Autoicon1.png" or "Off".
Read more: http://www.ehow.com/way_5585650_brookstone-digital-desk-clock-instructions.html#ixzz2phA7kQ1b
Jan 07, 2014 | Brookstone Self-Setting Atomic LCD Clock
Need a user manual for skyscan model 31420e atom travel clock
Late to the party I guess. Lots of entries for setting the clock, but not for the alarm. Press the plus or minus button. That's it. After you have the time set, you can then press the ALARM button above the WAVE/SET button to turn it on.
May 06, 2012 | Audio Players & Recorders
How do I change the time one hour ahead for an RP5430A model clock radio?
Slide the Wake 1/Wake2/Clock switch to the Clock position. Then press the forward button to advance the clock by the needed amount of time. Then slide the switch back to the side with the key icon.
If you set the DST switch to ON, you can move the time zone switch to one time zone further east for a few weeks until the DST change in the program takes effect. Then move the time zone switch back to your current time zone. (Repeat this in the fall to correct for the later change in DST again). The exact length of time between when DST starts and ends versus when the clock will change the program will depend on when the clock was manufactured. Clocks built after July 2006 should have the correct DST programs. Clocks from earlier have a much shorter period of DST (April through Oct).
I hope this helps.
Mar 13, 2011 | RCA RP5430 Clock Radio
DST on MTG900
The MTG-900 supports automatic DST which can be activated in the time setting mode.  However, the ROM in the MTG-900 dates from before Congress (in their infinite ability to make mistakes) modified the DST schedule, so, instead of switching at the beginning of April and the end of October (as currently specified), it switches at the end of April and the beginning of October (as previously specified).
I do not believe that there is a way to change the DST scheduling or manually turn DST on or off.  I've resorted to changing the time zone manually and turning off the DST feature.  IOW, I set the timezone to Pacific (LAX) during PST, and, to Mountain (DEN) during PDT.
Mar 10, 2009 | Casio Atomic-Solar MTG900 Watch
Echo drive skyhawk,My watch's time zone is always one hour behind
You posted this in January, which is not during daylight savings time. The SMT setting doesn't turn on automatic DST switching for a particular timezone; rather, it is a manual override to adjust timezones to DST when it is actually active. There is no automatic DST adjustment for this watch (according to their FAQ). Turn SMT to OF for all timezones during winter months, and ON for applicable timezones during SuMmer Time (SMT).
Jan 17, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Correct Time Zone
Using the Emerson CKD5809C manual (also with SmartSet(tm) ), try Zone 4. TIME ZONE button: "04".
Zone 1: Atlantic Time
Zone 2: Easter Time (Default)
Zone 3: Central Time
Zone 4: Mountain Time
Zone 5: Pacific Time
Zone 6: Yukon Time
Zone 7: Hawaiian Time
Reference:
http://www.emersonelectronics.ca/emerson/en/category/list/694
or
http://www.emersonelectronics.ca/emerson/en/product/details/2361
As for disabling the Daylight Saving Time (DST) time change I have some guesses to try (not having one of these radios in my hand) or just skip to #4 below.
1. Manually setting the time and see if this disables the DST change.
2. Is there a Zone setting other than above? Like maybe a Zone 0? And then manually set the time.
3. Look at http://www.fixya.com/support/t236208-daylight_savings_time_adjustment for my solution there and try adjusting the DST Start to the same as DST End or DST Start and End with a month of 0 (if that is possible).
4. Or for the really desperate, change the Zone to 5 during DST and back to 4 during standard time (no worst off than with no DST auto setting.) (After I wrote this, I found an Emerson reference to no DST areas, Saskatchewan in this case, in the CKS1850C manual http://www.emersonelectronics.ca/emerson/en/product/details/2383, pg 9, and this is their solution.)
Oct 28, 2007 | Emerson CKS3029 Clock Radio
Daylight savings time again
Appparently the problem could be with your location, or just that there may be a delay before time correction until the old date - check again the link to amazon i posted before - there are a couple of new reviews that discusss the daylight saving issue, also - The US clock says; "I have a radio controlled clock that receives NIST time. Will the new rules affect me? Your radio controlled clock should automatically implement the new DST rules. The WWVB broadcast contains information that tells your clock whether DST or ST is currently in effect. NIST always sends this information to agree with the current DST rules, so your clock should change automatically on the day of the change, just as it has in previous years. If the time is wrong after the DST change, make sure that your clock has recently received the time signal. Many radio controlled clocks have a synchronization indicator that will tell you if your clock has recently synchronized. If the clock isn't receiving the signal, click here for some tips on improving reception. If it has received the signal recently, check to make sure that the clock's time zone setting is set properly. Also, if you live in an area where DST is not observed (Arizona, for example), you need to disable the automatic DST function on your clock. I have a non-radio controlled clock that used to automatically correct itself for DST. Will it still work? The only way to find out is to wait and see, or to contact the manufacturer of the clock. There are a large number of non-radio controlled clocks, marketed under names like "AUTOSET" or "SMARTSET" that have internal firmware that automatically changes the time by one hour on the transition days to and from DST. These clocks do not connect to a NIST time service, and some of them will no longer work properly due to the DST rule change. For example, clocks manufactured prior to the rule change will probably not switch to DST in March, but will wait until April in accordance with the old rule. If you have a clock like this that fails due to the new rules, your only recourse is to adjust the clock manually, or to contact the manufacturer and ask for an upgrade or a replacement. If you need to contact manufacturer check http://www.emersonscott.com/ezsetamclocr.html Hope this helps:)
Mar 11, 2007 | H.H. Scott SCR120 Clock Radio
La Crosse LaCrosse Atomic Digital Wall Clock with Wireless Temperature Sensor Logo
280 people viewed this question
Top La Crosse Measuring Tools & Sensors Experts
Marvin
Marvin
Ngoro
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
