Powermatic 2 Electric Cigarette Injector Machine Logo
Harry Urbach Posted on Jul 01, 2015
My injector comes off the holder before it is tube is filled periodically
  • Anonymous Jul 01, 2015
    tube come off holder before it is completely filled
    where can you get parts for Powermatic 2
Frank Hunter
Level 1:
New Friend:
  • Contributor 30 Answers
  • Posted on May 02, 2016
Frank Hunter
Contributor
Level 1:
New Friend:
Answers
30
Questions
0
Helped
51555
Points
68
You need to replace the bumper on the end of the paper holder, call them for replacement, very easy to do
Power numatic 2 electric power cigarette machine
This could be due to a broken wire, a loose terminal, or a burned-out injector coil .
I would recommend taking your device to a professional technician for repair. If you would like to try fixing it yourself, inspect the rubber piece that holds the tube. Chances are that it is worn and needs to be replaced. It won't hold the tube all the way if it is worn. A quick fix is to cut a piece of eraser of a pencil and glue it to the holder
1helpful
Need user guide for a powermatic 2 cigarette injector machine
Contact vendors on Amazon.com or other sites:
Example:
https://www.fandfwholesale.com/powermatic-ii-electric-cigarette-injector-machine.html
Quoting from link above:
"Powermatic II Cigarette Injector is an electric, spoon fed injector and the first product of its kind we've carried in quite a while. We have been very impressed with the function and ease this product offers. The spoon fed style of this injector eliminates many of the issues that other auger driven injectors have. This machine will make both king size and 100 mm tubes and features electronic jam protection to ensure that that the machine does not break from overfilling the chamber. The compact and lightweight design of this machine allows for easy use and storage. The large tobacco fed hopper and removable tobacco tray, will be sure to have you rolling cigarettes in three easy steps. 1. Plug in and turn on the power. 2. Lift the lever and fill the tobacco evenly. 3. Press the lever fully down to start filling your tubes. The product includes accessories to clean your machine and comes with a 1 year manufacturers warranty. Please fill out warranty card and mail in upon receiving machine. Machines cannot be sent back to Smokers Outlet Online, Inc. for refund or credit. -------------------------------------------------------------------------------- For Warranty service, all machines must be sent to: Powermatic Service Center 17005 Evergreen Place Suite B City of Industry, CA 91745 1-626-964-5678 zico.com@verizon.net"
Aug 17, 2018 • Cooking
Bowl fill tube comes loose and squirts all over the house
you can stick the tube all the way down if it is long enough or build your own holder. If you replace the ballcock with a modern one they come with all those parts to hold the hose down
Water is not coming out on the top of the fill tube that connects to the overflow tube
It doesn't usually have water coming out. If it fills the tank, it is ok. The water is coming out at the bottom anyway. However, the adjustment on the tube is off and not allowing water in .
1helpful
Unable to init.50 comes up on the screen
An error code 50 indicates a problem with the maintenance unit. This unit is responsible for cleaning out the ink tubes and supplying pressure to fill the ink tubes going to the printhead. It is a part that requires periodic replacement and you will need a trained technician to replace it. You can log on to brother-usa.com to find the nearest service center, or call 1-877-276-8437.
2helpful
Water leaking from top rear left of refrigerator and dripping on coil line in the back of unit. Inside is dry and no water on floor yet. Is it the ice maker connection? If so how do I access it?
You will have to remove the ice maker , to have access to the fill tube . Only 3 screws , hold the ice maker on . After removing , make sure the tube is not frozen inside , and that it is securely , pushed inside the fill tube holder . If frozen inside , then the water valve behind the refrig , where the wall water line connects to , on the refrig , will need replaced also , due to " seeping " , not closing completely , after filling .
1helpful
2answers
Water leaks out the top of the Injector Sleeve Bracket, which does not have a cover. Is this part necessary? Can the 2 water tubes be joined by a standard water tight connector?
if this part is about 2 1/2" long and black rubber and has a white plastic tube inside it, yes it is necessary and do not take it out. the rubber is probably getting thin and causing the leak. they are not expensive parts and should be replaced. can do yourself.
New Pegasus Dual Flush Toilet Water does not enter Toilet bowl
There is a small plastic tube that comes from the fill valve and attaches onto the overflow tube on the flush valve. If no water is coming out of that tube, then it is clogged internally. You can remove the tube from the fill valve and take a small piece of wire or a straight pin to try and clear it from the outside. If that doesn't work, then I would recommend replacing the fill valve. They are inexpensive to replace. If you don't know how to get into the fill valve's internal guts at the top, then I would recommend replacement of the valve. One more thing, there also could be a water saver where the outlet is on the little tube I just explained. It is usually light blue, you can remove that and discard it.
10helpful
2answers
2003 vw jetta tdi fuel filter
It is on the passenger side right behind the washer fluid fill tube. You can follow the fuel lines (look like 1/4" black tubes, some are clear) from the injector pump to it. It is a caniser a bit bigger than a normal looking oil filter and sits between the washer bottle and the metal that forms the wheel well. It is held in by a screw type clamp about half way down the cylinder. Probably isn't the fuel filter unless there is air in the lines to the injector pump or they didn't bother to fill the fuel filter up with diesel after putting it in. There is not a fuel pump in the tank in these cars so everything is sucked up by the injector pump and it needs to be primed properly.
1helpful
Maytag A512 Leaks out airgap when draining/spinning out
Check pump. I would say it is the most likely cause for the water leak, especially if itdoes it while filling and on spin as the pump holds some residual water in it . That is normal.
Top Powermatic Cooking Experts
ADMIN Andrew
ADMIN Andrew
Billie Aukuso
john h
Are you a Powermatic Cooking Expert? Answer questions, earn points and help others
