I didn't notice this when I bought it but almost all the pictures I take come out with a red or green glow line that crosses the picture. It's not a dead pixel, the line is more faded and thicker. I tried taking pictures with all settings and different lighting but it seems to be random. PLease help!
SOURCE: saturation of unrealistic color
It is definite CCD chip problem. If you are within warranty period, send it back quick. They probably replace with other unit because the parts are not available for the product. Good luck.
SOURCE: yellow pictures
If it is in proper colors in daylight, It has to be no FLASH, or a bad CD.
I assume both video and STILL pictures are the same.
Did you ever get good pictures??
colors can be SHIFTED in most DIGITAL photo programs, your pictures may be saved (able).
David
SOURCE: Nikon D50 Set Problem - Won't Take Pictures
The F-- error means that the lens is not communicating or has lost communication, with the body. I would first try cleaning the contacts on the lens and body. You might also try another lens. This problem has been known to develop when using a heavier, large lens. It seems like you have had the unit for a number of years. Has this always been an issue?
Hope that helps,
-WN
SOURCE: blurry pictures....
reset the camera and try taking pictures using by soft pressing the shutter instead of a hard press... on digital cameras, hard fast pressing will cause the picture quality to be not as good
SOURCE: Red light keeps blinking when I try and take a picture
actually the flash ckt is having problem that is the reason the red indicater blinks. you can take photographs with flash off mode,to solve this problem you will have to contact service centre
Ready light does not turn on and the camera does not work.
Turn on the camera (Turning on the camera).
Install new batteries (Loading the battery) or charge rechargeable batteries.
Turn camera off, then back on.
Ready light blinks green.
Camera is operating normally.
Ready light blinks amber.
Wait. Resume picture taking when the light stops blinking and turns green.
Ready light blinks red and camera turns off.
Ready light glows steady red.
Transfer pictures to the computer (Transferring pictures with the USB cable), delete pictures from the camera (Deleting pictures/videos), switch image storage locations (), or insert a card with available memory (Using an optional SD/SDHC or MMC card).
Wait. Resume picture taking when the light turns green.
Change the image storage location to internal memory (), or use a different card.
Ready light is off or glows steady green.
