Question about LG FLATRON L1919S-SF 19 inch LCD Monitor
My LG flatron L1919S is not powering on.It hapend when the picture was working but the power light was of so i unpluged it and it isnt working any more
    Master:
  • 680 Answers
Take it in and have it tested Best Buy.
Terry
Posted on Jul 04, 2015
Driver download
type "driver LG FLATRON L1919S" in Google, you'll get the answer...
Aug 30, 2014 | LG Flatron L1919S LCD Monitor
Lg logo appears then goes in to power saving mode LG Flatron Wide Monitor
Hello davidhague99 ,
Check your VGA cable if connected properly to your CPU or Video Accelerator Card,if connected properly,try another VGA cable and if the problem persist you need to try another source.
hope it helps thanks
Jun 11, 2011 | LG FLATRON L1919S-SF 19 inch LCD Monitor
I cant see the red color on my lg LCD (flatron l1919s). instead there is like a blue light in the screen (all the pictures and faces are blue, and red events are black).
Failing internal components (but first before sending in for repair, check the computer graphics card is ok, as this, or the VGA cable to monitor may be suspect)
In effect what is happening is that the hardware that controls the spread of green and red pixels on the screen has failed (happens over time), this will need repair or more likely replacement
Apr 20, 2011 | LG Flatron L1919S LCD Monitor
Lg flatron does not come on at all
Possible failure of the power supply section and so in this case the SMPS unit. I shall give you a link on possible SMPS failures.
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Mar 23, 2011 | LG Flatron L1919S LCD Monitor
Flatron L1919S (Black) LCD Monitor: Is my LCD monitor, LG Flatron L1918S, good enough ...
You should google this. After looking myself i have seen that it should play HD movies without a problem.
May 18, 2010 | LG Flatron L1919S LCD Monitor
Powering up problem with my lg flatron plazma tv
Those lights are a code. I don't know which TV you have, exactly. But the manual will tell you what the light code indicates and what to do about it.
Oct 16, 2017 | LG Flatron L1919S LCD Monitor
LG FLATRON L1919S-SF  19 inch LCD Monitor Logo
159 people viewed this question
Top LG Computers & Internet Experts
Ekse
Troy Staley
Troy Staley
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
