Question about Nintendo Wii Sports for Wii
I have an older wii sport that was missing the sensor (RVL-014) and controller (RV-003) + (RVL-004)nunchuk. The console is an Australian (RVL-001).
I replaced them online, with an (RVL-000) sensor and a no number controller and nunchuk from China, but the console doesn't recognize them and so I don't have a cursor. I have tried all the things suggested online to sync them etc. but no luck. I don't seem to be able to get the controller to sync definitely. The blue lights flash during the syncing process, but don't settle to a single light and looking through a camera I can't discern any lights on the sensor. Any suggestions about what I should do to sort this out?
Posted by suzannestall on
5 Related Answers
Anonymous
SOURCE: rock band guitar will not sync to wii
For me it was the white box that connects to the back of the wii. I tried everything from changing batteries in the guitar, to pressing white button on guitar, to restarting while holding white button down to screaming at the wii. Then I bought a new rockband guitar at best buy and the new guitar did not work until I swapped the white box (dongle?) that connects to the back of the Wii. One is for the drums and the other is for the guitars and mic. Hope this helps.
Posted on Jan 18, 2009
Anonymous
SOURCE: second wii controller is ot working on FIFA 09
press home button then go 2 wii remote settings then click on where the battery power is then you can sync your controllers
Posted on Apr 19, 2009
Anonymous
SOURCE: Guitar will not sync or stay synced.
just keep trying that happens to me all the time
Posted on Apr 26, 2009
Anonymous
SOURCE: remote dont work. lights just flash. tried to sync
Basic Question: Did you set up the sensor bar?
I'm assuming you follow the instructions to plug in the Wii and to attach the sensor bar to the console and position the sensor bar so it is either below or above the television.
The Wii remote flashes (more specifically the bottom row of four lights that indicate which player each remote belong to flashes) when a button is pushed on the control while the Wii is off.
If the Wii is on and simply sleeping (as evident by a blinking yellow light on the power button on the console) pushing the power button the control should turn on both the console and the remote. Be sure to aim the remote at the console when "waking" the Wii up and at the sensor bar once the Wii Menu loads. The remotes automatically turn off with lack of interaction.
To recap: Your remotes sound to be working fine. I would assume it might be a problem with the interaction between your console and the remotes or the setup of the console. The Wii Information Guide has pictures and pretty clear connection instructions that should help fix your problem.
If everything is set up correctly as per the instructions and your system still does not interact your sensor bar may be faulty or your console as I believe you're remotes work fine.
Posted on Jun 26, 2009
Anonymous
  • 22 Answers
SOURCE: lights on my wii guitar keep flashing constantly
try pressing the button on the little white box with the usb cord that connects to the wii
Posted on Aug 02, 2009
How do i fix a Wii
Try this. What are you trying to fix? You may not have to tear it apart.
Model rvl 001
Check all the connections of the cables from the wii to the television to its power source. You can also test the outlet that you are trying to use by plugging something else into it. You may find that the wii power cable will not send power to the wii and needs to be replaced.
Model rvl 001
Netflix is not pre-installed on the Wii. To install it, launch the Wii Shop Channel and click "Channels", then select it from the list (it is a free download).
Is it beyond repair if plugged in to 220V, but not used?
The higher voltage has burned out the unit. A step down transformer had to be used with your device.
Wii error code 4
Try connecting to a different Screen and if the problem follows the Wii... then you have your answer
Fix a stuck dvd in Wii
There are two ways, 1 stick a sqrewdriver into the slot or talk to nintendo for a repare
2helpful
Where can I find a user manual for my Wii RVL-001 (USA)?
These work for all type of wii models
http://gamesites.nintendo.com.au/support/Wii_Operations_Manual-SystemSetup_AUS.pdf
Thanks
1RepairStop.com
Power light went out and won't come on. Hasn't been played for a while. it is a wii model rvl-001[usa]
wii control doesn't turn lights on. if you twist it a bit, the lights go on. must have something a bit los inside. no tec service here
Can't play using standard controllers.
that depends on the game. some games require both wii mote and wiimote+nunchuk. IF the game has an option to disable this however, it would be in the main menu's options screen.
Nintendo Wii Sports for  Wii Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Ekse
Aron
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
