Question about Frymaster Dean Kitchen Appliances - Others
Do i need a pressure regulator
35lb deep fryer nat gas
Posted by Leo Banks on
johnny rebel
    Top Expert:
  • 10,875 Answers
Always
Posted on Jul 01, 2015
Flames cominhg out of flue
Hi I use to repair every kind of restaurant equipment under the sun..maybe I can help...Is this a new install of the fryer and it never did this before, or did this just start do this..If a new install, the first thing I would check is the gas regulator and see if it is for Nat gas or Lp gas, and find that out..cause it has to match what you have, comming into the building..usuall the gas valve has a sticker on it that says what the water columbs are like for Nat it is like 3-6, and for Lp(propane) it is like 5-12. Ive seen customers buy a used fryer, and install a LP fryer in a Natural gas build, and the valve lets too much gas to the burners, and it will shoot flames out the top..then you would have to buy and convert a gas valve, or use parts to convert it..let me know further..
Apr 20, 2014 | Pitco Frialator SG14 Deep Fryer
Does this unit require a pressure regulator
This unit should not require a regulator unless your gas pressure is more than 14" water column or 1/2 psi. In most applications this unit will not require an additional regulator as it uses a combination gas valve/regulator.
Apr 06, 2013 | Imperial IFS40 Deep Fryer
I have purchase 2 used FMP 40BSS fryers - originally Nat Gas - i want to convert them to LP - what is needed and can i do it myself?
To convert these to LP you must downsize the burner orifices and the pilot orifice. Also you must change the regulator on the gas valve to LP. Easy job.
Tom
Aug 14, 2010 | Cecilware FMP40BSS Deep Fryer
Lazy lighting
Check incoming gas pressure, you may also need to clean out gas orafices. make sure you have the right orafices installed(nat or LP)
Sep 10, 2009 | Pitco Frialator 35CS Deep Fryer
Bought a four basket fryer on an auction. It is a Model bb14, serial m25860 not sure if it is now Lp or NG. Pilot lights for both sides but does not light burners. Can hear the click on the thermostat....
Natural gas and LP gas run on different pressures. If it has been set up to run on LP and you hook it up to natural the burners will be very small and may not light due to LP works on a higher pressure than natural. If it is set up for natural and you use propane the flames could be way overgassed. One thing to check is what the appliance regulator spring is set for. There will be a cap on the regulator and when you remove the cap there is usually a small metal ring inside that sets the spring tension by flipping it's position. On top of the ring it will say NAT or LP. Now if you find this ring set on NAT then the appliance was probably running on Natural Gas and vice versa. If it is set up for LP and you go to Natural than the orfices can be drilled out and the appliance regulator tension cap flipped. If it is set up for Natural and you go to LP than it is best to replace the orfices with LP ones.
Sep 04, 2009 | Keating Instant Recovery 14BB (NG) Deep...
Doing nat. gas to lp converson on my SR42GNS. What and where do I find parts
you will need an LP orfice for each burner, an LP regulator & either a LP gas valve or a conversion kit for the existing valve. E-mail me at [email protected] with the model# & serial # to the unit & I will be able to get those parts right out to you.
captrick
Jul 04, 2009 | Frymaster Dean SR42G Deep Fryer
Change from natural gas to propane
1.You will need to change the pilot orifice and the burner orifices
2. You may need to change the gas control valve. Some gas control valves are made for natural gas and some are made for LP. They have regulators built-in, that deliver the correct pressure respectively. Natural gas is 3.5 inches of water column, LP is 10 inches of water column.
Some manufacturers sell kits to change the spring in the regulator from Nat to LP
You would need a parts breakdown on the specific model number of your fryer to find the parts you need. Hope this helps.
Apr 07, 2009 | Imperial IFS40 Deep Fryer
Pilot goes out
You definitely need to change the spring in the regulator. May need new pilot thermocouple
Jul 20, 2008 | Cecilware GF-10 Deep Fryer
Adjusting main burner flame
Goto the gas valve,you will see 2 slotted silver caps 1 small 1 big.unscrew the big cap then youll see a white plastic screw.turn this screw counterclockwise to increase the gas pressure,clockwise decreases pressure.nat. gas pressure should be 3.5 inches of water colum
Feb 11, 2008 | Pitco Frialator 35C Deep Fryer
Open Questions:
Kitchen Appliances - Others Logo
Top Frymaster Dean Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Paul Carew
Lawrence Oravetz
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
