Watches Logo
Lorenzo Molina Posted on Jun 30, 2015
Where can i find replacement parts like a back for the Accutron Breckenridge26B29
B24007 M7 waterproof stainless steel railroad approved no stem or buttons
It's an old accutron 214- manufactured 1967. Of course it depends on condition,but the 214 Accutron is very popular and even not working should bring around $50.00 if it is complete, no missing parts. It could possibly bring $75 or more.
2answers
Accutron breckenridge instruction manual
Recently lost the 4 screws that fastens the back plate of my Accutron Breckenridge 26B29. Am looking for wrist band extensions for this watch too. I tried Bulova but they were of no help. Any ideas of where I could find these parts or even just the dimensions of the screws?
1helpful
Will loose from 10 minutes in one half hour or during a few hours it will loose from 15 minutes
try replacing i mean put in a new battery in it..
OR
open it if you can or take it to the nearby watch shop and tell them to clean it- sometimes dust sticks in and it hangs...
this will definately sdolve the problem
-waiting for top ratings from you
Accutron 2181 hums and second hand turns smoothly...BUT... the watch "stops" after a while and may re-start on its own, but loses large amounts of time. I have viewed the mechanism using a high...
With a watch of this age (assuming that it has been well used), it is likely that there is terminal were on the gears.
If you look closely at the mechanism when it has stopped, I would expect to seen a tooth that is more worn than the ones either side of it, causing the adjacent gear to miss engagement.
Comparison of teeth my be subjective, as I would expect many of the teeth to be showing wear.
I suspect that the only long term solution is a complete overhaul, if Accutron have the appropriate parts still in production.
How do I tell what model Accutron I own? I obtained it as a graduation present in 1972. The serial number is H233723.
The only people who are likely to be able to answer your question is accutron (assuming that they keep records that far back- which they might).
Go to http://www.bulova.com/brands/accutron/accutron.aspx?brand=accutron and scroll down to the bottom of the screen and click on "contact us"
1helpful
My watch stopped working. I think I just need to replace the battery in it. how do I get the back of the watch off to do that?
Bulova Accutron watches were originally designed to use Mercury batteries of 1.35 volts, since they were the only type manufactured then. The pic (left) shows an original 214 all-metal "top hat" cell, before 387 cells with the plastic spacer became available. In most areas of the world, mercury-based batteries are no longer available, due to environmental concerns related to the safe disposal of them. The Tuning Fork watches manufactured by Esa (e.g the f300 Omega) were designed to run on either mercury or silver oxide batteries without any adjustment, provided the last repairer to work on the watch set up the index mechanism according to factory specifications.
It is strongly recommended that you do not replace batteries yourself, as special tools are required to open the watch case without damaging it. The only exception to this is the Accutron 214 model, which has a small battery hatch on the back.
What is the worth of a bulova accutron 14kt gold mother of pearl face serial #59252 worth
mcdevito75 here, Bulova Accutron, nice watch, of course there are many, many factors that go into the value of any watch, depending on Maker, Model, Condition of the watch also. I would figure your Bulova Accutron is in the area of $125.00------- $200.00 range. Your best bet is to find a jeweler in your area or an appraiser, even online for the latest value of your watch.
RUNNING FAST
Accutron is made by Bulova. Follow this link and click on Accutron: http://www.bulova.com/index.aspx At the bottom of page click on CONTACT US. Rate me, please.
1helpful
I have an accutron and i want to reset the my
No need to go to the shop as you can reset chrono hand yourself. Read manual and follow instructions. If you don't have manual, try this: Pull out crown and then push the button and hold it. If this does not work, try push and hold the button whilst other one is held pushed. In short terms - try to use as many different combinations as you can and you will find which way is right.
Accutron Tahoe Chronograph
i have the same watch it needs a cleaning by a watch maker not jewler hope this helps
Top Accutron Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Accutron Watch Expert? Answer questions, earn points and help others
