When i press Start Button, Air start inflating and r reading reaches upto 160, which is most of the time is an incorrect reading. When Air Inflation is upto 200, reading is accurate. But i dont know how to set Air inflation upto 200, it is happening automatically 2-3 times per 30 readings.
Batteries are new and equipment is brand new as well.
If you are having trouble getting the air pump or inflator to work on your Power on Board jump start system, there are a few things you can try:
Make sure the device is properly connected: Ensure that the air pump or inflator is properly connected to the Power on Board jump start system. Check the connections and ensure that they are secure.
Check the power source: Ensure that the Power on Board jump start system is fully charged or connected to a power source. If the device is not properly charged or connected to a power source, it may not be able to provide enough power to operate the air pump or inflator.
Check the settings: Check the settings on the Power on Board jump start system to ensure that the air pump or inflator is properly configured. Make sure that the device is set to the correct pressure level and that the settings are not preventing the device from operating properly.
Try a different outlet: If you are using a power outlet to operate the air pump or inflator, try plugging it into a different outlet. This may help to ensure that the device is getting the power it needs to operate properly.
Contact customer support: If you have tried these steps and are still having trouble getting the air pump or inflator to work on your Power on Board jump start system, contact customer support for assistance. They may be able to provide additional troubleshooting steps or help you to resolve the issue.
OPERATION WARNING: To avoid the risk of personal injury, especially to the eyes, face or skin, DO NOT direct the air stream at any person. 1. Remove tire valve cap. 2. With clip-on air chuck lever depressed, firmly press chuck onto tire valve stem and release lever, ensure that no air leaks. 3. Press the grip to inflate, press the grip half-way to deflate. 4. On: Press the on/unit/light button to turn on the inflator. The inflator has an auto shut off to prolong battery life: it will turn off automatically 90 seconds later. 5. Backlight: When the inflator is on, press the on/unit/light button to turn on the backlight, so to read the pressure easily in darkness, the backlight will extinguish automatically in 5 seconds. Backlight will not be activated by turning on the inflator, can only be activated by pressing the on/unit/light button. 6. Unit Change: Press on/unit/light button above 3 seconds, enter unit change mode, then press on/unit/light button shortly to choose the desired unit. The unit chosen will be default unit for following usage. 7. The inflator’s battery is CR2450, 2.4-3.6VDC, if the voltage is below 2.4V, the low battery signal on the top left will be flashing continuously, to remind user to change the battery. Refer to the battery changing directions in this manual. 8. Measuring Range: 0-12BAR (0-175PSI). Reading Accuracy is 0.01BAR (0.1PSI). Max. Inlet Pressure is 15BAR (218PSI).
If you move your arm or wrist during and after the cuff has inflated, the device will "bump" itself up to start reading at a higher number. Make sure you hold your wrist at about the same elevation as your heart, in order to get the correct blood pressure readings.
its just dirty contacts if you can open your keyboard, clean contacts with non rubber eraser like the ones used by engineers and draftsmen. also include the rubber contacts under the keys
+ air intake : This will cover the cleanliness of carburetor or throttle body and the air filter. Make sure there is no obstruction in the air intake system and no carbon deposits or dirt. This is the most important part to get better air flow and fuel consumption. also tires, make sure there at proper inflation. please go here to read more because there are numerous causes for this.www. kereta.info/causes-of-high-fuel-consumption good-day !
E might represents insufficient inflation for your mom. For automatic inflation monitors usually there is a mechanism to keep inflating the cuff to higher pressures for people with higher BP. Check how is done. In some auto monitors,while cuff is inflated you keep pressing on START button until pressure reaches to some 15 to 20 mmHg higher than the pressure that auto usually stops and displays E.
EE=Cuff under-inflated=not inflated enough. While cuff is inflated, keep pressing START button until pressure reaches 15-20 mmHg higher than the pressure when it stops and displays EE. Make sure at least 5 min allowed between readings.
Check your tire air pressure at least once a week and before long trips. Be sure to use an accurate pressure gauge.
-Check your air pressure when the tires are cold. The tires are cold when your motorcycle has been ridden less than a mile at moderate speed or after being stopped for three or more hours.
-If you must add air when your tires are hot, add four pounds per square inch (4 psi)(28 kPa) above the recommended cold inflation pressure. Recheck the inflation pressure when the tire is cold.
-Never release air from a hot tire in order to reach the recommended cold tire pressure. -Normal riding causes tires to run hotter and inflation pressure to increase. If you release air when your tires are hot, you may dangerously under inflate your tires.
-If your tires lose more than two pounds per square inch (2 psi)(14 kPa) per month, the tire, the valve, or wheel may be damaged. Consult your local dealer for an inspection.
-Use valve caps to keep valve cores clean, clear of debris and to help guard against air leakage.
