Receiving cartridge error consilt user guide, can you help mke?
Posted by Bessie... on
Jay Plesset
  • Office Equip... Master
  • 2,942 Answers
Well, without knowing what printer it is or the full text of the error message, or what lead up to your proboem, this is a guess.
Wrong ink cart.
Empty ink cart
Missing ink cart.
Mis-installed ink cart.
Many ink carts have a piece of tape over the contacts or over an air breather hole. This must be removed before installing it.
Some printers have delicate contacts that can be bent or broken if the cart isn't installed carefully.
Posted on Jun 29, 2015
Lexmark X5650 cartridge error consult user's guide
Don't know for sure, but I found some user manuals on amazon, which can be helpful... take a look here: Amazon com lexmark manual I hope this helped you. Have a nice day
Mar 23, 2012 | Lexmark X5650 AllInOne InkJet Printer
My black cartridge was running low but was still printing. Then I got the Cartridge error message and to consult my user guide. I have misplaced the booklet. I replaced the black ink cartridge and...
Welcome to Fixya. If you lost the user guide on how to fix the error perhaps the link below will help you out your problem. It contains solution on how to fix cartridge error and the proper way to replace cartridge.
Dell AIO 948 Troubleshooting
Thanks
Jun 17, 2011 | Dell 948 All-In-One InkJet Printer
Receiving cartridge error and consult user guide
Remove both cartridges from your printer. Close the cover. Unplug and replug your printer into the power source to reset it. When the printer turns on, reinsert one cartridge first. Close the cover. Check for any error. If none, open the cover and reinsert the other cartridge. Check for any error. Replace whichever cartridge is causing the error to display. Or you could try to insert a different known good cartridge to determine if the other is faulty.
Apr 25, 2011 | Lexmark X4650 InkJet Printer
Installed refilled ink catriges,both black and color used for a few days all was well then, it reads Catridge Error -Error: 50C Go to users guide. what do I do Now cannot find users guide. plzzz help.
Though Lexmark does not recommend using refilled inks. You may refer to this article from the Lexmark website on Cartridge Error 50C and Other Errors on the Lexmark X5100/X6100 Series LCD Screen. If this does not help, try to insert a genuine Lexmark cartridge to determine if your other cartridge is faulty. Thanks.
Feb 24, 2011 | Lexmark X6150 All-In-One InkJet Printer
I have a dell all in one printer 962. It suddenly started giving me a catridge error....error 1203--consult user guide. The user guide tells me nothing. I have uninstalled and reinstalled the printer. ...
Dell All-in-One Printer Cartridge Error 1203.
There is a short in the cartridge you have. You need to cover a copper contact on the color cartridge the error clears and the cartridge works. Looking from the contact side for the color cartridge 2nd row contact 2 from the left. Use a SMALL square piece of Scotch tape to cover that contact. If you need more help let me know thanks
Jun 20, 2010 | Dell 962 Photo All-In-One InkJet Printer
Printer Cartridge Error Message
Hi there
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
All the best Pineworks
Apr 03, 2010 | Lexmark X7170 All-In-One InkJet Printer
Cartridge Error 50C consult user guide. I
Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Nov 10, 2009 | Lexmark X6170 All-In-One InkJet Printer
I am receiving cartridge error - 50C. I have
Hi there Error 50c
This happens a lot in dell printers.
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Mar 31, 2009 | Dell A940 All-In-One InkJet Printer
Cartridge error
what make and model???
need more information.
every printer have its unique problem.
Oct 16, 2008 | Lexmark X6170 All-In-One InkJet Printer
My Lexmark is X6100 Series - Cartridge Error 50C consult user guide
Cartridge Error 50C
Cartridge Error
Jan 14, 2008 | Lexmark X6170 All-In-One InkJet Printer
82 people viewed this question
Marvin
Marvin
